Is this load ready to go?
Discussion in 'Flatbed Trucking Forum' started by TravR1, Jan 22, 2022.
  1. TravR1
    TravR1 Road Train Member
    3,695
    9,786
    Nov 9, 2017
    TX
    Dispatch says it's about 40k. Nothing on the bills.
    OH->CA so it will see a lot of terrain.
    I don't want no explosions.
  3. Kyle G.
    Kyle G. Road Train Member
    3,903
    20,582
    Jan 23, 2016
    Eastern Iowa
  4. Kyle G.
    3,903
    20,582
    Jan 23, 2016
    Eastern Iowa
    I’d definitely be using all those winches
  5. TravR1
    3,695
    9,786
    Nov 9, 2017
    TX
    Structural laminating? The bills don't say. It looks like some type of wood.
    Theres like 11-12 straps on there I think. The load up there on the step I hard to get at without falling.
    singlescrewshaker and Kyle G. Thank this.
  6. TravR1
    3,695
    9,786
    Nov 9, 2017
    TX
    More straps? I got more.
  7. Vampire
    Vampire Heavy Load Member
    772
    27,685
    May 14, 2011
    Transylvania
    Put them inside the rub rails while you're at it.
  8. Kyle G.
    3,903
    20,582
    Jan 23, 2016
    Eastern Iowa
    Since I don’t really know anything about the material, I probably can’t be much help. But one thing that concerns me is the two bundles on top that only have one strap over the center. That causes the material to flex into a u-shape, which can cause the dunnage to slowly walk out as you go down the road. Also, I don’t know how much flex you want in that kind of material?? Sometimes putting a flex in the load is a good thing because it can help prevent sliding, but you need to make sure that, a. the material can flex without damaging it, and b. that the dunnage won’t walk out.
    So at the very least, try to get two straps over those top bundles and when you are done, you should try and push on each piece of dunnage and make sure they are all tight. Sometimes with a load like that with a million pieces of dunnage, you will end up with one or two loose ones.
    Looks like you are going a long way with this one so you will definitely need to keep an eye on it.
  9. MOBee
    MOBee Road Train Member
    1,774
    10,159
    Apr 27, 2014
    Anytime dispatch "says it is X weight" they probably really don't know for sure. Scale in the yard? Close by?
  10. bags
    bags Bobtail Member
    20
    58
    Aug 6, 2009
    Colorado
    I thought the load pic was a joke for the members at first. I haven't seen a mess like that in years. The dunnage will walk and straps will be loose 20 miles down the road--- my favorite is the rear pallet with one strap and not centered on the trailer--- who knows when that might leave.
  11. TravR1
    3,695
    9,786
    Nov 9, 2017
    TX
    On my dispatch the notes say, "do not be afraid to over tighten. So my guess is the material can flex under the straps.
    That stack on top of my step worries me a little. It's stacked high and it's difficult for me to get straps through it.
