Is this solution legal?
Discussion in 'Volvo Forum' started by Benek, Mar 12, 2017.
  1. Benek
    Benek Light Load Member
    83
    39
    Feb 10, 2016
    Gotta small leak in the same place, took this picture of a company truck and 20160916_095855.jpg wander is that legal,
  3. xsetra
    xsetra Road Train Member
    5,197
    7,148
    Aug 21, 2011
    Is that rtv?
    I welded an oversize washer to stop a leak in the same place, until I could replace the steering sector.
    Don't know if it was legal, but it worked.
    Benek and Dave_in_AZ Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    I do not remember reading where there are regulations on what type of seal has to retain the oil. However that is a halfway repair and could be a precursor to a internal problem. Instead of worry about if it is legal I would worry about if it is safe. It maybe a little different if you are just running around town but if you are running the road a break down will cost you many times over doing it at home.
    Running it low on oil repeatedly can cost you a pump.
    Thank that is just a dust cap and the seal is inside. Not a job for most people.
    Don't take chances on steering and brakes!
  5. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    I second the notion of the safety aspect being the primary concern.
    Benek Thanks this.
  6. Benek
    83
    39
    Feb 10, 2016
    Just replaced seal on top,,the one on pic leaks approximately 2,3 drops overnight.my "trusted "mechanic tells me if I wanna spend money -go ahead replace it. but if it's only a couple drops a night, just wipe the #### off.I'm confused as ####
