Is Window Tinting a Magnet for DOT?
Discussion in 'Ask An Owner Operator' started by PE_T, Dec 30, 2018.
  1. PE_T
    PE_T Road Train Member
    I want to tint my windows legally (70%), but if it means DOT will be pulling me over all the time, then I’d rather not have it on. Has anyone tried it?
    FMCSA regulation:
    Regulations Section
  3. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    Get the Mirrored glass like the limos had in the 70's and 80's......
    That way- You can laugh at the cop trying to see inside, but the only thing he'll see is his own face,
    Try that 1 out if you want.
    PE_T Thanks this.
  4. Badmon
    Badmon Heavy Load Member
    806
    1,503
    Oct 6, 2014
    Deep south
    Lots of can haulers around my way ride with some pretty dark windows... I'd say go for it you'll probably be good
    PE_T Thanks this.
  5. GreenPete359
    GreenPete359 Road Train Member
    2,252
    5,423
    Oct 21, 2017
    Driving my recliner
    I used to run 35% for years. Never got questioned about it. Inspected many times and not a word.
    I’d love to run 20% on my Pete, in Jersey it’s only a $54 ticket. But the whole csa crap is what stops me. No need collecting points from mindless b/s when you may need that clean record if poop ever hits the fan. I don’t need the head aches
    CorsairFanboy and PE_T Thank this.
  6. Idahojoel
    Idahojoel Light Load Member
    63
    48
    Jan 17, 2018
    Phoenix Arizona
    I see Lots of local trucks in my area running limo tint.
    Keep in mind We don’t have any scales or P.O.E to deal with just ADOT enforcement and AZ DPS CEB
    PE_T Thanks this.
  7. Fewe
    Fewe Light Load Member
    293
    288
    Aug 20, 2010
    Arlington, TN
    I've been running 70% for 3 years now. The actual tint is less because of the factory "tint" on the windows. I don't remember what the actual tint that was installed but a little trial and error with a tint checker before install got me legal. You can't even tell the windows are tinted from the inside or the outside. After 3 years the tint is getting scratched up from the windows going up and down so I may pull it off eventually. If it comes off it won't be going back on. It does help to keep some heat out during the summer and my left arm doesn't have an uneven tan but I'm not sure it is worth having.
    AVL and PE_T Thank this.
  8. PE_T
    It seems like the factory tint cannot be removed, right?
  9. Fewe
    293
    288
    Aug 20, 2010
    Arlington, TN
    Correct, it is in the glass from what I could tell. It isn't much, maybe 4-5 percent. I don't remember exactly.
    PE_T Thanks this.
  10. AlexanderK
    AlexanderK Light Load Member
    156
    95
    Mar 11, 2017
    I think each state determines percentage and tint regulations.
    Tb0n3, Sirscrapntruckalot and PE_T Thank this.
  11. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Correct. It's baked into the glass.
    PE_T Thanks this.
