Hello,
Volvo i-shift makes grinding noise and takes a second when going into 8 or 9 gear. Once it's in everything works just fine. Gears 1-7 switches fine and 10-12 also works great. New clutch and all oils at normal levels. Had Truck connected to computer and it's showing mechanical failure, no check engine light on.Truck drove 7k miles with this issue, will be put out of service so this issue can be resolved.
I heard it could be a splinter in the transmission, or some other mechanical failure. Any advice where this can be fixed and what are my options.
Thank you
Ishift shifting
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Onway, Nov 4, 2017.
