Just bought a 2015 volvo vnl and I got had….new to being an O/O. Got a good price on it but immediately found out it needed a clutch assembly replaced. Replaced a whole mess of parts but still having issues. Now the when the truck downshifts I have to come to a complete stop and start over. The truck shifts upwards just fine but hesitates at the start and then almost slams into gear. Any thoughts?
Ishift trans problems
Discussion in 'Ask An Owner Operator' started by Tmurf423, Apr 21, 2023.
Should have gotten the U-shift option.
Stringb8n Thanks this. -
I am not sure and not very mechanically inclined, but when they replaced the clutch did they replace the actuator? I have read from other posts by a knowledgeable mechanic who posts on here a lot that deals with Volvo trucks that if you replace the clutch you may as well replace the actuator while you are there as well. @nasriza is the Volvo guru. May take a minute for him to get on here and see, but I am sure if he sees the thread he will offer some advice.Siinman Thanks this.
You need to have it scanned. There is a ribbon cable in the transmission that connects the shift position sensors to the TCU The cable fails over time and can cause a number of problems.
