Ishift - Whine sound
Discussion in 'Volvo Forum' started by palmeris, May 8, 2024.
  1. palmeris
    palmeris Bobtail Member
    36
    18
    May 18, 2023
    2019 860- purchased used with 592000 ish miles. has a turbo like whine sound from tranny in any gear up to 6th, once past 6th it disappears - no codes thrown - shifts fine with no apparent issues- anyone seen this before, thoughts?
  3. 86scotty
    86scotty Road Train Member
    4,723
    12,974
    Aug 27, 2017
    Appalachia
    Last fluid/filter change? Fluid level?
    Siinman and palmeris Thank this.
  4. palmeris
    36
    18
    May 18, 2023
    Fluids and filter changed last month, less thank 2k miles since. Cold level on site glass is right at Minimum . sight glass.jpg
    86scotty Thanks this.
  5. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    I'm guessing 13 or 14 speed?
    If so , that's 100% normal on the "X series" (HD) iShift with hardened gear set
    palmeris and 86scotty Thank this.
  6. palmeris
    36
    18
    May 18, 2023
    Thank you for the reply.
    It is a standard I-shift 12 speed. It has the performance shifter push button selectors on the dash. It also makes the turbo whine sound if your in manual .
    Its a D13 425 HP 1750 with a 2.64
    Old mark and KB3MMX Thank this.
  7. 86scotty
    4,723
    12,974
    Aug 27, 2017
    Appalachia
    I can't help but I'm curious what you find out. For reference my fluid sits about there too and I had it done about 6 months ago.
    KB3MMX and palmeris Thank this.
  8. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    the only thing that will change in the trans before and after 6 gear is your range selection in the back might have a bad bearing for output shaft that is whining also might be a slight angle adjustment on your driveline but i do not believe so. most likely something with range synchro or a bearing starting to fail. that fluid level is little bit low for my liking need to probably add a little bit maybe about .5 to 1 gal.
    NWAF, KB3MMX and palmeris Thank this.
  9. palmeris
    36
    18
    May 18, 2023
    Thank you very much for the response. It did seem to be right at the min mark , I figured the service shop had a purpose for it being that low...sigh. So do I put fluid in at location 3 or 4 on this diagram? tranny page.jpg
  10. palmeris
    36
    18
    May 18, 2023
    It also has the brass drain plug so I use the 75w-80 correct? tranny fluid.jpg
  11. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
