Issues...?!
Discussion in 'Questions From New Drivers' started by Southern2aTea, Dec 30, 2012.
  1. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    QC problems usually require a :
    1) Competent FM / clerk whom is computer literate in Windows
    And / or
    2) a trip to a service center
    Depends on what's going on etc. Tell hubby to be careful and be sure paper matches exactly. If QC has power then it's tracking and the data is somewhere. He might not be able to see it but it's either stored in the unit, on the server in San Diego or on the FM's computer.
    Point: I've seen a paper vs a qc argument and the qc won.
    NavigatorWife and TRKRSHONEY Thank this.
  3. pokerhound67
    pokerhound67 Heavy Load Member
    801
    665
    Oct 30, 2012
    the secret they arent telling you is...wait til you are FAR AWAY from a terminal to bring up repair issues, especially if you have knowledge of a specific terminal being bad at repairing in a timely manner. then they will have to route you to a t/a or dealer, both of which will perform the work better and quicker.
  4. Southern2aTea
    Southern2aTea Bobtail Member
    11
    4
    Oct 5, 2012
    St. Augustine , Fl
    I appreciate all the advice. What was happening specifically is that he would certify the logs and then overnight sometime they would delete and switch to 24 hours off duty. When he first started having trouble with it he told them and he started keeping paper logs. He is very detail oriented and is all about safety. He follows the rules so I'm not worried about him getting in trouble. I just wasn't sure if this was a normal thing. Btw he didn't just go to the terminal just to get that fixed his parking break has been slipping so he needed to get that looked at. I love getting on this site because I can almost always get a quick answer and support!
  5. pick
    pick Bobtail Member
    37
    12
    Jun 25, 2011
    the desert North of Ellay
    The QC is an issue that they can't really address unless they have spares sitting around to swap out - so, him being there all day and nothing getting done about the QC is not unheard of. The last company I ran with had a box of spares and still could not always keep up with the issues. At least they addressed some of the other issues it sounds like. So, yes, the frustration of sitting all day in the yard is a fact of life that will not always happen, but most assuredly does in this industry.
    Happy New Year to you and your man and best wishes for an excellent 2013 full of miles and running for him!
    Later
    pick
    TRKRSHONEY Thanks this.
  6. TRKRSHONEY
    TRKRSHONEY Heavy Load Member
    726
    420
    Apr 23, 2009
    Knoxville, TN
    An additional FYI about QCs, there are only about 24 repair centers across the US. Hubby's messed up a couple of years ago (before he was on e-logs) and it took 6 weeks before he was able to get into an area where he could get it fixed.
    chalupa Thanks this.
  7. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,081
    Apr 30, 2012
    Cental West, AL
    Also did you make sure safety was called about the issue. Husbands had been down completely before with no screen and it makes life a lot harder when you have to call and get all info by phone. He was on paper logs then luckily.
    The last time on this company that QC was down with the elogs he did paper logs and they had to be sent in trip pak: log department had a hard time for whatever reason getting the elogs and paper logs to marry up they said.
    He most likely was sitting because they didn't have a load for him to take also.
  8. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    I was expecting the trucking industry to be a whole lot worse where I would break down at least once every week and have to sit and wait for days all of the time... with that mindset I was surprised that I could go months without any delays or problems. Yes, I travel all over the US and Canada and always manage to avoid traffic and without any breakdowns that cause me to sit. I had a few problems that could be fixed later and I did have a flat trailer tire but I was still in the sleeper and had a lot of time until my appointment. When passing my terminal when I was ready to shutdown I would have mechanics do maintenance checks on my truck while I slept to keep things tip top.
  9. cuzzin it
    cuzzin it Road Train Member
    3,647
    13,088
    Jan 19, 2008
    Berea, KY
    using paper logs instead of being babysitted by a qualcom IS A GOOD THANG !
  10. passingthru69
    Remember, anything made by man can be broke by man.
    Les, I like your thinking...
    Me I love not being on elogs...
    Oh wait I'm home on holiday....
    Les2, Logan76 and 'olhand Thank this.
  11. NavigatorWife
    2,937
    2,081
    Apr 30, 2012
    Cental West, AL
    Husband has a 2012 Prostar International in August he was brokedown in Sparks, NV, 8/15 to 8/22when out of shop. P/u load went Stockton, CA dlvd, p/u new load 8/22, broke down again then so it is at Turlock dealer from then till fixed again 9/4. He stayed in truck maybe 3 days total before they got it into the shop, the rest was in a motel .
    He made it to within 45 miles of dlv 12/11, brokedown again. In motel till finished 12/18.
    Since he is a lease operator this is all out of our pockets for the motel expenses and no money made during downtime.
    He says the check engine light is on once again. He also was in shop in Jerome, ID for about 2 days back in Feb for problems, they did work on it and got the truck out and let them stay in it when it wasn't being worked on. Luckily it was all on warranty work, but it seems to be that some of the dealers appeared to let trucksahead that were paying customers vs warranty work.
