ISX 475 vs. ISX 400 ST
Discussion in 'Trucks [ Eighteen Wheelers ]' started by vadim2200, Feb 1, 2011.
  1. vadim2200
    vadim2200 Light Load Member
    128
    36
    Nov 21, 2010
    Other then HP, what else is different? Torque? The Mechanical parts should be the same right?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    compare CPLs. Part lists are different, turbos, injectors...
  4. king Q
    king Q Road Train Member
    2,881
    3,047
    Jul 26, 2010
    Johannesburg sa
    The ones we get here have the same peak torque.
    I don't if the know torque curve is the same.
  5. vadim2200
    128
    36
    Nov 21, 2010
    will i feel the difference if i upgrade ISX 400ST to 475 HP and set it to same torque as 475isx
  6. king Q
    2,881
    3,047
    Jul 26, 2010
    Johannesburg sa
    If you are loaded heavy , run fast or drive in mountainous areas you will.
    On relatively flat ground with light loads under 65 the difference will be negligible.
    Unless you are using more then 400hp to propel the truck you won't notice , it in nice to have it in reserve though.
  7. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    The big deifference is the ST in the name. The ST stands for Smart Torque. What you have are two different peak torque amount during operation. For all of the gears except the top two would have for example 1450 or 1550 lbs ft of torque and then you might have 1650 or 1750 lbs ft of torque in the top two gears. It is for fuel economy reasons. I have been able to tell the person that owns the truck what the torque rating of the engine is when I drive it. You can and will feel a difference in the performance between the two trucks. The torque curve is similar, but not the same on both ratings. Also you will not be able to upgrade the 400hp to 475hp without mechanical changes to the engine.
    vadim2200 and The Challenger Thank this.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    There are CPLs for every engine. According CPL I choose calibration file to let engine run properly. Some "smart" guys use to put 475 HP calibration to engine that was designed for 430 HP maximum!
  9. vadim2200
    128
    36
    Nov 21, 2010
    I spoke to cummins service, and they told me that the there are no differences between the two engines other then Smart Torque and HP, and that 400HP can be upgraded to 500HP and the engine will work fine, it would be the same as if you buy your truck from manufacturer where on the plate of the engine states isx500.
  10. king Q
    2,881
    3,047
    Jul 26, 2010
    Johannesburg sa
    Smart Torque is sometimes programed in to engines for the sake of the drive-line when in lower gears.
    No good uprating an engine if the rest of the drive is already at its limit.
  11. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Don't worry about the driveline. Unless it's out of a pickup 100hp isn't going to blow things apart. There are plenty of guys with 700hp to the ground running a driveline ordered for 475 with no catastrophic failures. The way you drive makes all the difference.
