ISX 550 kenworth coolant level
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Nov 9, 2023.
  1. Perchie15
    Perchie15 Light Load Member
    247
    75
    Aug 16, 2021
    I am having issues with a ISX Cummins it keeps saying low coolant but it’s topped up, I bypassed the prongs coming off the sensor only 2 prongs there but still showing the light. It’s one of them hard plastic reservoirs. Even when I disconnect the plug
    From the sensor still says low coolant!! Meter reading 5.0k ohms off the sensor
  3. Transportauto
    Transportauto Light Load Member
    100
    34
    Apr 10, 2022
    Sounds like wiring back to the ecm.
    Test them for resistance to ground verify there integrity.
  4. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    If it is like mine (2013 660) there is a float inside the tank that will stick and cause this. Unplugging sensor check engine light stays on low coolant specific light goes off. Just a thought. Could be lots of other things as well.
  5. Diesel Dave
    9,665
    32,744
    Jan 20, 2010
    Hesperia, Ca.
    I had the same issue on my 2014 Pete, I changed 2 coolant sensors(different times), the light went away each time then come back on. Then I changed the coolant reservoir(was already getting deteriorated), light still wouldn’t go away. So I had a tech look at it and ended being a wiring issue by the ECM.
    Perchie15 Thanks this.
