ISX CM 2250 reliable?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Diesel Dan 92, Aug 28, 2016.
  1. Diesel Dan 92
    Diesel Dan 92 Light Load Member
    137
    50
    Nov 27, 2015
    Looking at a 480k truck that's spec'd perfect for me but the local truckers I know say the motors are junk. The truck is already pushing it on cost I can't afford a blown engine.
    It's a 2011 ISX at 500
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    I would pass, the best Cummins ISX15 motors to date are the CM2350 MY 2014 and up, as they had scrapers on the piston rings because the earlier CM2350 had carbon packing issues on the pistons.
    The CM2250 had issues with the Ceramic Fuel Pump Plunger coming apart and going through the oiling system and wiping out the engine.
    They also have problems with Counterbore Fretting, where the liners are rotating inside the Counterbore taking out the machining marks which the first sign would be a blown head gasket. The fix to this problem is to replace the liners with the updated ones which is almost like doing an Inframe.
    There have also been problems with the Oil Pump Drive cracking causing a loss of oil pressure.
    There are many Owners that have had good luck with the ISX15, but I've heard and read far less then more.
    It's a Used Truck, so you're going to take your chances.
    Do your research and read everything that's out there about the ISX15 or any other motor out there, ask tons of questions before purchasing any Truck and ask for receipts and service records.
    Cat sdp Thanks this.
  4. Diesel Dan 92
    137
    50
    Nov 27, 2015
    Thanks for the reply.
    Anything that can be done about the fuel pump?
    Truck would be getting full deletes if I got it "off-road use"
  5. boneebone
    2,297
    2,372
    Mar 13, 2009
    Make sure the Fuel Pump and Cam Followers were replaced already or replace the pump if you know it's the original one if you decide to purchase it.
    I believe there was a TSB issued regarding this problem.
  6. killer120
    killer120 Light Load Member
    70
    43
    Jul 1, 2013
    its known for fuel problems and egr problems, isn't that the one with overhead cams? I know the cummins with overhead cams were a pain in the ### so they changed the design
  7. spax
    spax Medium Load Member
    361
    364
    Aug 5, 2011
    United States
    That was through cm871's which went partially into '11, his will be different
  8. killer120
    70
    43
    Jul 1, 2013
    ah I see, I haven't had too much experience around isx engines, the fleet I work on is all m11, ism, n14, ntc400, 855's and Volvo d16's, why the company decided to get rid of the old pete's with 3406b's and c15's I will never know, but I'm sure #### pissed they got rid of them, those old cats pulled so much harder, a 475 was pulling better than one of these 600 d16's, they were so much easier to fix too, now I gotta use this stupid volcom stuff and cummins insight, all the #### electronic ######## haha, the c15's had electronic injection but still was so much more simple to do inframes and to maintain
  9. killer120
    70
    43
    Jul 1, 2013
    also we used power box's on the cat engines, brought some from 475 to 600 and around 2k to 2200 torque
