Isx code
Discussion in 'Volvo Forum' started by vitaliko, Jan 26, 2014.
  1. vitaliko
    vitaliko Bobtail Member
    17
    Hi guys i need little help! I have recive (check engine faul and code Mid 128 Sid 27 Fmi 7).In 09 Volvo 670 isx engine maybe some one know what this code mean?? Thank you for your help....
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    stuck EGR position Sensor
  4. vitaliko
    17
    Hi Pablo i was on petro shop they told me next(vgt actuator driver circuit (motor)
    mechanical system not responding properly or out of adjusment. The smart Vgt controlerhas detected incorrect stop limits,or the VGT is unablevto move to the closed position(flash code 2387) ) can i still drive??? Thank you!!!
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yes, u can, but bad vgt will go worse soon. the problem is that it is usually worn inside turbine ore incominated with soot. to be sure U have to remove turbo and inspect it
    ok, it is not all, if ECM throws 2387 code u should run Turbo/EGR test with insite and see in what limits actuatot gets in stuck
  6. vitaliko
    17
    How you think this vgt can damadge turbo?
