ISX coolant cold weather Drip
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pawpaw1, Dec 31, 2012.
  1. pawpaw1
    pawpaw1 Medium Load Member
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    Hi, all!
    OK. Starting last winter , and re- appearing now that temps are 35 degrees , and below, I have a coolant Drip when the engine is cold , from a round " tube " that is Behind the water pump. It is not the water pump . I was advised there is an O-ring back there that will cause this, and have the new O-ring.
    My question is, how difficult is it to get TO this O-ring ?
    Appears I'll have to remove the water pump , but don't know what else ? Anyone done this job before, or know of a resource to point to , to get this done ?
    KW says it takes about 4 hours. 4 X $115.00 per hour equals I'll do it myself !
    Thanks !
  3. twolane
    twolane Medium Load Member
    468
    252
    Dec 16, 2010
    Arizona
    It's probably not an "O" ring. It may be a simple "cold-water-leak" that happens to hoses. Silicone hoses are worst for this. Tighten ALL the hose-clamps and see what happens overnight unless yer sure it's an "o" ring problem.
    Heavyd Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Any way you could take a picture and upload it?
  5. pawpaw1
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    Yea , I can , when it starts dripping again. May not get cold enough here tonight. I Hope ! Hate losing anti-freeze.
    However , I'm Sure it's not a hose. I've seen where its leaking from. It's Behind the water pump housing.
  6. Radman
    Radman Road Train Member
    2,087
    2,559
    Apr 18, 2011
    It's the water pump o ring. Happened to my daycab. Mechanics say it's cause when it gets really cold it cracks it. My truck had a big puddle after it sat thru the weekend.
    pawpaw1 Thanks this.
  7. pawpaw1
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    Yup. Seems the colder it is , the more it leaks. Advice on how to replace it ?
  8. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    There is a tube that runs directly behind the water pump that goes to the egr cooler older isx uses 3 o-rings isx 15 uses two
  9. 508darrinh
    508darrinh Bobtail Member
    21
    4
    Dec 2, 2012
    Lakeville, MA
    The oil coolers on the cats do the same thing in the cold.
  10. pawpaw1
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    Hummm! Mines a 2006 . How many for it ?
    and , how difficult is it ?
    Thanks !
  11. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Takes 3 pawpaw make sure to clean out where the orings go with some emry cloth so not to damage the new o rings not bad 2 bolts
