ISX cracked block
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BoxCarKidd, Oct 30, 2026 at 11:24 PM.
  1. BoxCarKidd
    BoxCarKidd Road Train Member
    4,611
    6,771
    Aug 26, 2014
    A friend of mine has a 2011 ISX serial # 79441714. It was inframed by a truck dealership 100,000 miles ago.
    Now the block is cracked on the left side a little behind the air compressor and about 3 inched below the head gasket.
    singlescrewshaker and D.Tibbitt Thank this.
  3. BoxCarKidd
    4,611
    6,771
    Aug 26, 2014
    Did not mean to post this yet as I am still working on this. Wondering if it is possible for rolled liner o rings the crack a block on these.
  4. Goodysnap
    Goodysnap Road Train Member
    3,827
    9,361
    Jul 12, 2017
    Seems like I saw one other crack in that same spot. I doubt the rebuild or workmanship has any effect on the crack in that area.
    Is it leaking? Oil?
    Just sucks
  5. pushbroom
    pushbroom Road Train Member
    1,792
    7,438
    Sep 1, 2012
    Seen 2 blocks crack in that exact area. No ones fault, just falls under #### that happens. Crack is coming off the main oil gallery. I dont have any side pics but this is the pic with the front structure removed.
  6. BoxCarKidd
    4,611
    6,771
    Aug 26, 2014
  7. BoxCarKidd
    4,611
    6,771
    Aug 26, 2014
  8. Nss
    Nss Light Load Member
    132
    263
    Jul 5, 2021
    Is it possible where a head bolt goes into block? Have seen that on numerous blocks that head bolt holes did not get cleaned out before assembly
  9. BoxCarKidd
    4,611
    6,771
    Aug 26, 2014
    Do you suppose it would take a year and 100,000 miles to show up?
  10. DUNE-T
    DUNE-T Road Train Member
    7,108
    17,347
    May 10, 2015
    Detroit, MI
    I have seen quite a few ISXs crack in that spot
  11. SmallPackage
    5,985
    19,368
    Dec 20, 2019
    Marion Texas
    A friend of mine has tested thousands of diesel engines at Southwest Research. He says a crack in a block like that is almost always caused by harmonic flexing. In other words. The vibration that goes through the casting during low rpm lugging. Look at the way the casting shifted over at the too of that crack in the pic. That is a tell tale of it. It is from shaking side to side. Not being pressed up or down.
