isx cummins is stuttering
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cory A, Nov 8, 2019.
  1. Cory A
    Cory A Bobtail Member
    Nov 8, 2019
    I'm new to this thing so y'all bear with me. i just bought a 2011 Peterbilt 389 with an ISX CM2250. the engine was rebuilt 2 years ago and fully deleted at the time. when i go the truck home and got it on the road i found the fuel pump was leaking oil from it's gastket. Last weekend i removed all the lines moved the pump back about 5 inches from the front cover removed and replaced the gasket. got everything bolted back up on Saturday and was ready to work on Monday. It ran great on the first load I hauled with it. apprx. 160 miles or so. When I left that site, i got some minor hesitation and sputtering from the engine. No codes or check engine lights. Day 2 started ok for the first couple of hours and then the same problem.It seems to be doing this loaded or unloaded. Usually when starting a pull, (does exellent durring the pull) and when coming out of one. I've since replaced all the older fuel lines with new ones. Still the same. Although, its seems to be a bit better today, it's still not like it should be. Would a leaking injector cause this reaction, or is it more of an electrical issue? It feels like it's sucking air in the fuel system, but there are no leaks present. I've also presureized the system and nothing. Had it going down the road last night with a tech in the passenger seat reading the fuel pressure and other various thing with his diagnostic cmputer and everything read normal. Even he tought it was crazy. Kind of at a loss here and don't know what else to do. Anyone got any ideas? Thanks
    SimpleTrucker Thanks this.
  3. AModelCat
    164,652
    Stuttering? Like a chugging noise? Most, if not all ISX's sound like they're about to throw a rod lol.
    HoneyBadger67, miszel and swaan Thank this.
  4. AModelCat
    164,652
    This is what I'm refering to by chugging:
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
  6. Caleb5178
    Caleb5178 Bobtail Member
    @cory
    Did you ever figure this out I'm having the same issue
  7. drivinhome
    drivinhome Light Load Member
    91
    102
    Sep 16, 2009
    Southeastern Mass
    Vibration damper. They last no more than 500k typically. Hard to tell from the video but the injectors can easily be checked.
  8. Choptopmerc50
    Choptopmerc50 Bobtail Member
    Fuel pump is out of time with the engine. Cummins has a TSB about it causing chugging
  9. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    On the last cat I drove. It only acted up when it was hot. Everything got replaced.
    Took new injectors to fix it.
