ISX Cummins leaking diesel
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Bigtruckdrivah, Oct 31, 2020.
  1. Bigtruckdrivah
    Bigtruckdrivah Light Load Member
    186
    224
    May 31, 2020
    Older ISX, in a 2003 9400i. This is the last of my leaks! Didn’t even know it was leaking until I got all the oil leaks fixed.
    it’s leaking from the driver side, seems like mostly when it’s shut off, I assume the Fuel distribution “thingy” don’t know the name. The triangular piece was leaking but I replaced gaskets in it and it’s good. I’m not sure if it’s the solenoids leaking or my make feed portion where the line comes in. Is there a rebuild kit for this thing? I’d attach a few pics but I’m not sure how! Do I need a hosting site to post pics here?
    Dave_in_AZ Thanks this.
  3. AModelCat
    164,846
    Click the "Upload A File" button and select the pictures you want to attach to your post.
    spsauerland Thanks this.
  4. Bigtruckdrivah
    186
    224
    May 31, 2020
    I’m an idiot. Thanks for the help
  5. Bigtruckdrivah
    186
    224
    May 31, 2020
    You can see a drip in this one. It looks like a few of the solenoids are leaking. I don’t know which is fuel though
  6. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Those 4 solenoids are called metering valves. Cummins makes a kit that has oring and plate. (1) Do one at a time. Inside valves and outside valves look the same, but are different part numbers. (2) when you take them off, parts will "explode" like jack in the box. Put them back in EXACT ORDER they came out.
  7. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Yup........
    Inside actuators are for fuel injection timing.
    Outside actuators are metering or quantity of the fuel injected.
  8. Eboogey
    Eboogey Bobtail Member
    10
    4
    Nov 4, 2020
    Not sure about yours, but I have a 2011 ISX 15 and my fuel pump is two pieces, the head and the body between both is a gasket. I just ordered the parts to rebuild the head which includes the tappets, barrel and plungers and the gasket. Youtube has videos and I heard on at least one that they will leak fuel. Try the QuickServeMobile app it will give you part numbers and you can buy on Shopcummins.com
