ISX Cylinder liner sinking causing head gasket failure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Truck engine machinist, May 2, 2020.
  1. Truck engine machinist
    Truck engine machinist Light Load Member
    195
    188
    Dec 2, 2011
    USA
    For all of you ISX mechanics. If you are working on a 2013 1/2, and newer, ISX, with factory brass cylinder liner shims, you will usually find that the counterbores are not fretted at all. Liners go down, because the brass bearings (as Cummins calls them) (ie shims) have smashed. I now have stainless steel shims, that you can install, in place of the brass shims, and get the liners up to .014" protrusion, without doing any machining of the counterbores.
  3. AModelCat
    164,846
    Funny Cummins engineers can't figure this stuff out but a machinist can.
    The stainless shims holding up good?
    JolliRoger, D.Tibbitt and Shawn2130 Thank this.
  4. Truck engine machinist
    195
    188
    Dec 2, 2011
    USA
    Holding up very good. I am selling these all over the country, for years Every one is extremely happy with the results. Most of my customers will not put a ISX together, without S/S shims. Cummins will have to do something else. I have seen many, many brass shim failures, (One was smashed .010" on one side of the liner. .000" smash on the other side) Those truckers are very upset, with Cummins. One fleet has two 2014s that failed. Has two more to go. When???
  5. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Very interesting? Thank you for sharing!!!!!
    I have a 2350 apart now with #5 dropped to .003 and a plain as day blown gasket.
    Have you sourced the shims from a third party manufacturer? "No detailIs required, just curious" I will most definately will be mic'ing these once apart.
    spsauerland and Dave_in_AZ Thank this.
  6. White_lightning1983
    White_lightning1983 Light Load Member
    54
    27
    Aug 1, 2019
    What about the 2014 isx motors? How do they hold up?
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Let us know what you find with your measurements.
    Goodysnap Thanks this.
  8. Goodysnap
    3,773
    9,199
    Jul 12, 2017
    This is #5 my suspect hole and liner was low and measured .005" on the Hot side. All liners measure at minimum spec or below on the hot side. Cold side was around .010"
    The shim is cracked on the Hot side. Shim Mic'd .026" at the same spot the liner was low. All other spots mic around .032". There is evidence of fretting on all 6. This one is the worst.
  9. Truck engine machinist
    195
    188
    Dec 2, 2011
    USA
  10. Truck engine machinist
    195
    188
    Dec 2, 2011
    USA
  11. Goodysnap
    3,773
    9,199
    Jul 12, 2017
    Less than 450 on the clock
