isx mileage
Discussion in 'Volvo Forum' started by waltherz, Apr 11, 2019.
  1. waltherz
    waltherz Light Load Member
    133
    13
    Dec 12, 2012
    I would like know what is the mileage per galon for a volvo 2010 with cummins 450 with 13 speed. This truck loaded is doing 5 to 5.5, I think is poor mileage. Thanks for any opinion.
  3. Dave_in_AZ
    424,236
    How fast are you cruising, what part of the country? How much idling? I had a 670 that I could only squeeze about 6 or 6.2 out of. Cascadia's are good for 1 mpg more.
    KB3MMX and Socal Xpress Thank this.
  4. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    Does your truck still has dpf and maybe def system??? Beginning of April most truck stops switch over to summer blend diesel, you might be getting better fuel mileage soooon.
    KB3MMX Thanks this.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    What rears and cruising rpm are you at? If your doing 70-75 you aren't gonna break out of the 5's
    KB3MMX Thanks this.
  6. waltherz
    133
    13
    Dec 12, 2012
    Thanks your opinions, the truck is running northeast to TX and midwest, I would like know an average in round trip , not at specific area, because the truck mountain and plain areas. Thanks again.
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    If 3.25-3.58 rears...
    Speed low 60s and driven for MPG , low to mid 7s , with an APU no idling.
    Driven like a hammer head and idled regularly... 5-5.5 is about tops... Maybe less
    OP .... What rears ??
    What cruise speed ??
  8. just_sayin
    just_sayin Light Load Member
    104
    167
    Sep 2, 2012
    Bristol baby
    2009 ISX. Emissions delete. set at 550 horsepower..Borg Warner Turbo. full tilt manifold.386 Peterbilt ,13 speed 3:55 gears. Lowepro 22-5 rubber. I run from Virginia to Phoenix twice a month. 20 to 25 thousand in the Box. Cruise speed 65.. RPMs 1430. Idle less than 15%. Anywhere from 7.5 to 8.2
    KB3MMX and waltherz Thank this.
  9. waltherz
    133
    13
    Dec 12, 2012
    Did you raise up to 550?my truck has 450 and reggens system. Thinking in emission delete and raise up to 500 hp. I had 1 driver and he did 4.7 mpg, the current driver improve to 5.5 pmg.
  10. just_sayin
    104
    167
    Sep 2, 2012
    Bristol baby
    Yeah I had it reprogrammed to 550. All the emissions garbage is gone it's not even on the motor anymore. I think of a lot of the reason I get that mileage is I run it real easy. If I ran 70 75 I doubt I would get 6 miles to the gallon. And I forgot I pull a dry box with no skirts
    KB3MMX Thanks this.
  11. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Sounds like a big part is the drivers.
    Lock that thing down and you'll see it improve ...
    just_sayin Thanks this.
