isx oil pressure problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 388petedh, Jun 14, 2011.
  1. Williamgon
    Williamgon Bobtail Member
    18
    Jun 1, 2009
    USA
    the fleetguard filter for the isx was updated from the lf 9000 to the lf 9070 these are the long versions, there is also a shorter version. the media was redisgned for better flow and filtration. as stated before the egr isx were plugging filters and when i spoke to cummins tech support they stated there is also a software update to change timing and decrease the soot levels. ( at least on the CM870 2004 emissions engines)
  3. thesvg
    thesvg Light Load Member
    192
    13
    Dec 9, 2010
    I have low oil pressure problems all the time (N14) I installed a manual gauge and all my problems were over, something is wrong with my sending unit wiring. but The mechanical is working so i am in no rush to fix it :D
  4. wilke
    wilke Bobtail Member
    10
    5
    Aug 11, 2012
    illinois
    My oil pressure was 22. Took me $1000 to find out when they serviced it they put a smaller oil filter on. If you have a dpf system you need the longer filter specificly designed for it. Took three dealers b4 they found it. It is a common error.
  5. woody69
    woody69 Bobtail Member
    I would have the static injection timing checked, cummins has been finding that some of the isx engines timing is retarded creating soot (plugging filters), poor starting, and poss engine performance and fuel milage. I am not talking about pinning the crank and putting the wedges in the cams, but dial indicating the piston to injector travel. If your mechanic is good he will know about this... it is in the cummins web sight. If the engine is off in timing and in warranty cummins will pay for the change, It has to be out so much for them to pay, but a good mech will make up the numbers. If it is not in warranty it will cost you about a 1000 to have it done, pulling the cam gears, reset the timing and run the over head. hope this helps. I have been a mechanic for 26 years
  6. Cencal transfer
    Cencal transfer Bobtail Member
    I have a 08isx every 5000 mi oil filter plugs , loose oil pressure and shut down. Change filter and all good for another 5000 mi. Replaced cam , no change . Tried all different brand filter , Baldwin, fleet guard , ect . No change engine has 450,000 . 5 different shops no answer for problem. Sounds like a common problem
  7. Goodysnap
    Goodysnap Road Train Member
    3,772
    9,196
    Jul 12, 2017
    Get oil tested. Probably coolant in the oil.
    QUALITYTRUCK and SL3406 Thank this.
