ISX - SCR Efficiency Low 4364
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gregoryr6, May 6, 2020.
  1. Gregoryr6
    Gregoryr6 Bobtail Member
    6
    I have 2013 KW T660 with ISX 15 665K miles
    My check engine light is on for code 4364 - SCR
    Efficiency Low, I’ve replaced so many parts:
    DPF filter, inlet NOx sensor, outlet NOx sensor,
    DEF dozer, DEF filter, diesel dozer(7th injector),
    couple temp sensors and still getting
    Fault code 4364....can someone help?
  3. Goodysnap
    Goodysnap Road Train Member
    3,796
    9,244
    Jul 12, 2017
  4. Gregoryr6
    6
  5. Goodysnap
    3,796
    9,244
    Jul 12, 2017
    Engine serial number please
  6. Gregoryr6
    6
  7. Goodysnap
    3,796
    9,244
    Jul 12, 2017
    Your fault code listed does not exist under an ISX15 or under the ESN given.
    What tool are you reading with or do you have a different fault code?
  8. Gregoryr6
    6
  9. Gregoryr6
    6
  10. Gregoryr6
    6
    4364 and 3582 is the same code
