ISX15 Emissions Codes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JohnIC, May 15, 2024.
  1. JohnIC
    JohnIC Bobtail Member
    19
    11
    Dec 24, 2023
    Have a list of codes I pulled up from key on/off and need help on this one. See attached list of codes with their descriptions. Where do I start?
    To me it feels like like NOx sensors are out of range from other codes, essentially its a chain reaction here.
  3. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Enter the codes that happened within the last 25 operating hours into the fault code analyzer on QSOL. This will put the codes in the recommended order to troubleshoot. Generally focus on active codes or codes with higher counts. Do not bother with any older codes and that are 1 count only and inactive status.
    Keep in mind if you’re using Insite, The last code that changed status from active to inactive will be on the bottom of the list. So if no codes are active the most recent is at the bottom. Timestamps are the key.
    Otr Traveler Thanks this.
  4. JohnIC
    19
    11
    Dec 24, 2023
  5. JohnIC
    19
    11
    Dec 24, 2023
    I don't have insite. Seems like I need one to avoid chasing the tail with heavy price tag. Until I get one, if there is a way without it (from key on/off)? I do have message saying "SCR/FPF service required".
  6. Goodysnap
    3,773
    9,199
    Jul 12, 2017
    With what I know I would begin with 3232 code. Most commonly a wiring issues to the Nox sensors and controller. Sensors are not common for the codes. ECM is not communicating with the component. Check Power and ground to both sensors.
