Isx15 horrible mpg
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Isx15451hp, Nov 25, 2019.
  1. Isx15451hp
    Isx15451hp Bobtail Member
    Year ago I purchased 2014 Volvo vnl630 with isx 15 engine 451hp ,10 speed Eaton transmission, 3:55 differential ratio , hauling 53 flat bed , first thing I noticed it was getting 5.2 mpg ,on good day 5.6 empty or loaded did not make much difference, than it start give me lots of problems with after treatment system.. I caved in got egr dpf def deleted , figured my mpg will be better I was wrong because that didn’t help too , rpms was running high 70 mph at 1600 rpm , so trow in 22.5 11 r at it now at 70 mph at 14500 rpm for few days after tires it was doing 6.2 to 7.0 mpg I was so happy . now it drop to 4.7 mpg any ideas ??? By the way fuel filters changed every 15k changed intake manifold pressure sensor , changed air filter , changed crank case filter ..
  3. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    First thing is I hope whomever removed those items from your truck put in a good program for the computer or fuel mileage will be the least of your worries.
    How many miles on it?
    KB3MMX and AModelCat Thank this.
  4. Scoot 1971
    Scoot 1971 Light Load Member
    265
    348
    Nov 22, 2018
    Problem is, you bought an ISX! Do a little more research next time.
    PE_T and KB3MMX Thank this.
  5. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Fix with Volvo D13 XE , throw away ISX
  6. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    I have an ISX15 485hp backed by a 13 speed Ultrashift Plus and 3:55s. I also average 8mpg hauling steel.
    I considered doing a delete until I did some serious research into it. That whole motor is a single organism with every part supporting every other part. Deleting the EGR can lead to possible cracked heads due to overheating if the delete isn't done correctly.
    Personally, I'm keeping my after treatment system. I'm just looking for more economical methods of cleaning and maintaining the system. The possible associated costs of a delete just do not make financial sense to me.
    You want to run without it? Cool and good for you. I'd recommend getting yourself a pre-EGR truck then, and get very familiar with your tools (a good idea no matter what truck you run).
    spsauerland, bzinger and Dave_in_AZ Thank this.
  7. Dave_in_AZ
    426,160
    I'm at 7.3 lifetime with my ISX coming up on 700K miles.
    10 speed manual/ 3.58 rears.
    With 3.55's, you're gonna need to slow down.
    Once you're cruising over 1400 rpms, it's gonna suck fuel.
    PE_T and bzinger Thank this.
  8. Dave_in_AZ
    426,160
    I had a Volvo with D13 and 3.55's.
    It was all I could do to get 6.2 out of it.
    bzinger Thanks this.
  9. Mattmanstroked
    185
    279
    Nov 24, 2019
    What's your boost pressure reading? Have you tested your charge air cooler for leaks?
    Is fuel doser injector still plummed up? Could be dripping fuel into exhaust.
  10. brsims
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    Yours must be set up.different somehow from mine, Dave. Mine gets the best fuel mileage cruising at about 1530 rpm. Puts the motor right up close to the top of the powerband, and let's me walk up the Kentucky hillsides without issue.
    Today, for example. 523 miles (big day for me), 60 gallons burned. My math shows that as just a hair under 8.72 mpg. Not bad with 43,000 on the deck coming out of Kentucky to the other side of Erie, PA.
    Dave_in_AZ Thanks this.
  11. Mattmanstroked
    185
    279
    Nov 24, 2019
    You are doing really good on your fuel mileage. Wish I could do as good as you. I would be thrilled to get 8 mpg
