ISX450 and air leak
Discussion in 'Volvo Forum' started by ejm, Apr 15, 2012.
  1. ejm
    ejm Bobtail Member
    16
    6
    Dec 1, 2010
    I have an 05 670 with an ISX450. Right below the compressor is a box I'm not sure what it is but it seemed like it was leaking air at the 1/4 line that goes to the turbo. It would leak the truck air down to 60lbs in about 10 minutes. While checking the fitting it quit leaking. I'm sure this will come back to haunt me but I'm not sure what the box is to figure how to address it. Anyone know?
  3. haulhand
    haulhand Road Train Member
    That's the control for the variable vanes in the turbo. If it is blowing air out it has gone bad and needs replacing. That along with replacing EGR valves is a problem that plagues the ISX.
    - Sent from my iPhone using Tapatalk
  4. ejm
    ejm Bobtail Member
    16
    6
    Dec 1, 2010
    Thanks Haulhand. Where does the air come from, all I see is the line to the turbo and an electric plug on the left side. Trying to figure how this works.
  5. haulhand
    Best I can recall the air runs into the control module from the air tanks with a line on the backside of the module. It's been a couple years since I had my truck with an ISX so I could be wrong but I had to change that module twice on it.
  6. ejm
    ejm Bobtail Member
    16
    6
    Dec 1, 2010
    Ahh, guess I need to get in there and get a closer look. Thanks again.
  7. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    If its leaking from the fitting where 1/4 line comes in you can replace the fitting that's a common leak area
  8. QUALITYTRUCK
    1,820
    1,787
    Jun 14, 2009
    romulus,mi
    truckmechanic is right.after you see what "the box"costs.you will try like hell to replace that fitting!!good luck.
  9. ejm
    ejm Bobtail Member
    16
    6
    Dec 1, 2010
    I hear that... already checked pricing, must be gold in there somewhere. Hopefully the fitting is the only problem.
    Thanks all for the assist and info.
  10. Burdisco
    Burdisco Light Load Member
    121
    53
    Apr 25, 2015
    2005 ISX 500hp. I had the same issue. It was one of many air leaks. It's the push fitting. I walked over to the KW dealer only to discover that it's not fitted on their Isx, Volvo only. Can you post the volvo part number for the push fitting when you get it. The local dealer can't find it. Tks.
  11. ejm
    ejm Bobtail Member
    16
    6
    Dec 1, 2010
    Sorry Burdisco, I had to replace the whole turbo controller to solve my problem. Fortunately I found a new controller on ebay pretty reasonably priced. That leak was solved, now I have another that I can't find (yet).
