Jacknifed today when using the Jake Brake!
Discussion in 'Questions From New Drivers' started by TravR1, Dec 28, 2018.
  1. TravR1
    TravR1 Road Train Member
    3,695
    9,764
    Nov 9, 2017
    TX
    Well it wasn't bad. Nothing worthy of the road diner.
    Was headed west of Souix Falls looking to get on an intersecting ramp with another interstate. Roads were plowed, but not salted. It was about like 22 degrees out and a fair amount of wind.
    Came to my off ramp. I had let it coast down to 35mph then I moved right. It was a 25mph ramp so I wanted to slow more. I gave the jbrakes only 1 click. It started to slow and I felt that zero gravity feeling and my tractor slide to the right maybe 45 degrees or less. It happened so fast and it was dark I am not sure what my trailer did I could really see in mirror. It felt a little like I was flapping to the right like it wanted to answer my corrections but couldn't quite do it.
    Anyway I took off jakes and it came back under control. The whole thing only lasted about 4 seconds or 5. I tried my pedal brake after that by pumping and slowed it more then the Jake brake worked after that.
    Rest of the night went without incident and I got parked.
    I am confused how that happened. I was gentle with the controls and I did not use service brakes at the same time?
    That was a bit of a storm that blew through up here. Had to push a 4-wheeler out of snow stuck on a different on ramp earlier. Another trucker behind me waiting helped too.
  3. Nukem
    Nukem Road Train Member
    1,237
    1,447
    May 11, 2014
    Don't have much to say other than glad you got it under control and made it out safely. But it seems as this was one of those "life lessons" that you will never forget.
    Quoting a famous painter...
    This sounds like a "happy accident"
    Reflect and learn from it. You won't make the same mistakes twice.
  4. TravR1
    3,695
    9,764
    Nov 9, 2017
    TX
    I thought that 1 click on the jakes would be fine. Esp. Since I planned the approach and let it coast to a slow 35mph. But obviously something went wrong there. The service brakes worked better. The rest of the day and in even worse conditions earlier the Jakes worked fine.
    Rideandrepair Thanks this.
  5. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    how much weight did you have?
    a Cloverleaf ramp needs to be driven with a strong heart and patience in snow covered situations.
    Only "experience" will get you more pinpointed FEEL to how you drive in snow covered roads then to ramps.
    Were you shaking like a leaf on a tree? See,Its a good thing this happened to you, Now you'll appreciate snow and a truck in a different light.
    Rideandrepair, Oxbow, TNSquire and 2 others Thank this.
  6. TravR1
    3,695
    9,764
    Nov 9, 2017
    TX
    I only had two pallets in my trailer about on the drives. Not heavy at all.
    It was kind of like a shake. I am sure my trailer moved to the left a little, but not sure how much it was doing that I was mostly looking forward... Or technically off to the right I guess, lol.
    The car behind me didn't back off at all. When I looked behind me he was still right there on my tail. :confused:
    Rideandrepair, Mattflat362 and Lepton1 Thank this.
  7. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    The real question should be how much weight you had on drive axle(s) and trailer axle(s). The more weight you put on trailer axles with less on drive axles the higher chances of your truck jackknifing.
  8. Doealex
    597
    1,132
    Feb 21, 2018
    Oops. Posted this a second too late
  9. TravR1
    3,695
    9,764
    Nov 9, 2017
    TX
    Well thats good to know. Sometimes those dock people like to load the trailer weird. One time I opened the doors and the trailer was loaded fine until they got to the end by the doors then they decided to build a mountain of cheese or whatever it was. But that wasn't what I was doing here. I was doing pick ups.
    Rideandrepair and TNSquire Thank this.
  10. TravR1
    3,695
    9,764
    Nov 9, 2017
    TX
    And earlier that day in ND I was doing about 45 on an interstate. I was snowing and a lot of powder blow over on to the road. I had a whole parade of 4wheelers behind me following like ducklings.
    A Truck torpedoed by me doing like 60 or more. The backdraft from his trailer all that snow blinded me 100% for like 15 seconds! Maybe it wasn't that long, but it felt like forever. I couldn't see ####. By the time I could I was in the left lane heading towards the ditch. I corrected and the truck slide a little bit.
    I probably should have shut down for the day maybe. If you can't see that's just not good
    Rideandrepair, TNSquire and Lepton1 Thank this.
  11. IluvCATS
    IluvCATS Road Train Member
    4,089
    8,973
    Dec 1, 2014
    Seattle, WA
    Sounds frightening. Glad it wasn’t me!
    Rideandrepair, mad38dog and TravR1 Thank this.
