My dad has a 1999 Freightliner XL Classic with a 3406E Cat engine in it. When he uses the Jake Brake, he has an issue with the RPM's fluctuating. Anyone have any ideas what could be causing this?
Thanks in advance.
Jake Brake RPM Issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by muddflap12000, Oct 12, 2019.
Does the engine fluctuate also or just the tach?
He said the tach fluctuates, and he believes the engine does as well, he said he can hear the engine as well.
Sounds like you are saying it only happens with the jakes and the motor sounds like its missing. If its not missing and its just the tach jumping, just deal with it. My tach is jumpy with no engine miss. Annoying yes. So its fine otherwise? Other than that, sounds to me like one of the jakes might have a loose solenoid wire causing one of the jakes to intermittantly cut off and go back on in a fast sequence giving that feeling of a miss. If its not a loose wire, your gonna have to check the ohms at the wires down at the computer for the jakes. IF they arent in spec, you will have to check the ohms at the solenoids to rule out internal and external harness. IF all that checks out, its time to rebuild those old jakes. The jake kit for your motor is 160 bucks from cat and i have the part number for you if you need it but ill have to get in morning. it comes with all parts to do all 3 jakes. After the install of the kit, you will need to run your overhead. Once all that is done, you will be going through the windshield when you put the jakes on.
Forgot to ask, when was the last time an overhead was done on the truck. -
Okay, I'll let him know. It was a truck that was recently purchased. From what I can understand the overhaul was done within the last 200K Miles. I'll double check though.
Thanks for your quick replies! -
if thats how long it has been since the valves and jakes were adjusted, its time to run the overhead. To have a shop do it, it doesnt cost much. If the shop that did the overhaul has any sense, they were supposed to rebuild the jakes as well and install new solenoids along with replacing internal wire harness but you never know these days.Mike250rs Thanks this.
Jakes sending you through the windshield on a cat, this I have to see. lol
Collie, what kind of manifold pressure are you getting with your jakes? -
Don't confuse the jacobs bouncing around for being just too light overall gross for the job.
#### i cant remeber looking. only thing i remmber is the turbo screams pretty good when jaking. im not driving yet till i pull this trans again and then put another in.
