jake brakes
Discussion in 'Volvo Forum' started by nick1340, Apr 3, 2015.
  1. nick1340
    nick1340 Bobtail Member
    4
    Pittsburg,California
    jake brakes on cummins isx run intermittley
  3. Hick
    Hick Heavy Load Member
    928
    1,624
    Dec 4, 2014
    True or false?
    Hmm....
    False?
  4. 315wheelbase
    315wheelbase Heavy Load Member
    783
    602
    Oct 26, 2014
    sounds to me like a swith on the clutch might be adjusted wrong,,jake is either on or off also the jake runs on oil pressure so if the oil pressure is not constant it might deactivate the jake
  5. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Could also be a loose connection somewhere but some more truck info would be extremely helpful
  6. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Sometimes this board is like me being at my shop. Customer should realize that the more info that he gives me, the more helpful it will be when diagnosing and fixing the problem, thus taking less time ($$$) out of his pocket. Eventually I am going to find/fix the problem, but if I have to try and duplicate and verify every possible symptom on my own, it will take more time to do so. Just a thought (rant)!
  7. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Hi, about the engine brake problem when the problem occur check if the cruise control can work if not probably like someone told you earlier it's probably in the clutch pedal switch circuit , adjustement or switch itself.
    Ben
  8. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Also, i forgot to told you the ABS module have the capability to turn OFF the engine brake without any warning, then for a quick test you can remove the Abs fuses and try it just for a short period of time.
    Ben
  9. nick1340
    4
    thanks i took it to Volvo dealer and they did what they can (adjusted switch on clutch etc.) still could not find problem,still in limbo.
  10. nick1340
    4
    well guys I want to thank you for your input, I found the problem which the dealer could not, harness that goes into left side of the head was leaking oil from the plug due to damaged o ring oil on connection, replace the o rind cleaned out connection all done,could of saved 400. dollars
