jakes on isx
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NW can man, May 21, 2012.
  1. NW can man
    NW can man Light Load Member
    51
    9
    Apr 4, 2012
    Zillah WA
    I'm having problems with the jakes on my 04 w900 with a isx. I have stage one and 2 but not three i replaced the solenoid this weekend with no change. Today they hooked up a the dealer and said that we are getting power to the jakes and all looks good but they said we are gettting a code from our wastegate on the turbo is there any connection between the turbo and jakes? they want me to put on a new turbo and egr valve but im thinking its something else. Any suggestions would be great!!
  3. jorlee
    jorlee Light Load Member
    197
    83
    Feb 17, 2007
    ND
    I'll try and help ya.
    How much boost do you have with jake on 3? The harder I push the jake, the more boost I get. In a 05 ISX. Really helps to get a good overhead done too.
  4. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    The Vgt turbo is actuated to close the vanes more for the third stage so it is possible that it could be the turbo.
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    CM870s and newer use the VGT turbo for your stage three brake level. The turbo vanes will close and create some exhaust back pressure acting like an exhaust brake. The different levels you select with your switch also doesn't dictate what solenoids come on, the ECM senses the current operating conditions and selects what it thinks is best. If you physically can't feel any difference between levels they may be right with a turbo problem.
  6. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    +1 ^ what he said
  7. zeefarmer
    zeefarmer Bobtail Member
    May 24, 2012
    Saskatchewan
    Have you lost stage 3 quite suddenly, or over a period of time. I have a '00 ISX that lost stage 3 jakes slowly. Ended up replacing the cams as they had cavitated.
  8. NW can man
    51
    9
    Apr 4, 2012
    Zillah WA
    We found a code for a faulty crank sensor and when we replaced it they came back but still have a little falter at times so I'm going to replace the harness due to the fact that it looks pretty ratty. Will let you know what we find. The turbo is still running strong so I'm thinking maybe the shop jumped the gun little bit on that one! good thing i was a bit skeptical
  9. PROSTREET80
    PROSTREET80 Light Load Member
    75
    13
    Jul 11, 2012
    northwest AR
    How does it have three stages anyway it only has 2 jake solinoids instead of three I always wandered about that.
  10. Heavyd
    7,826
    6,276
    Feb 4, 2009
    One solenoid will control 4 brakes, and the second does 2 on the older engines.
    PROSTREET80 Thanks this.
