jumped the fifth wheel
Discussion in 'Questions From New Drivers' started by 4noReason, Jul 9, 2013.
  1. 4noReason
    4noReason Road Train Member
    2,401
    757
    Nov 29, 2012
    ok i jumped the fifth wheel took forever and i finally got out. what do you guys do when this happens? i couldnt dump my bags theres no air dump valve. so the guy on the phone told me go under fifth wheel and theres a bolt you can remove NEVER FOUND IT! anyways is there a company that comes out to help or is this one of those your stuck things. the landing gear wouldnt go up i dont know why finally it began to go up and i moved the fifth wheel straight and i slid from under it. so relieved. but now im paranoid.
  3. darknessesedge
    darknessesedge Medium Load Member
    650
    423
    Jul 8, 2013
    you have to raise the back of the 5th wheel up so its even horizontally..use your broom handle or a pole.....I have a crow bar that I keep for removing wood in the trlr..also a good weapon...
    then either lower the trk of raise the trlr...
  4. coastie
    coastie Road Train Member
    Also know as Highballing the trailer. It happens. Before backing under why it best to GET OUT AND LOOK at the height of the trailer. Nothing to be paranoid just learn from it and all is cool. But it does happen to the best of us (finger pointing at myself)
  5. DE36535
    DE36535 Light Load Member
    192
    147
    May 11, 2013
    Foley, AL
    Sounds like you fixed the problem. I'd be willing to bet you do that again!! Just remember - you're not the first person to ever make that mistake.
  6. USCG Aviator
    USCG Aviator Bobtail Member
    11
    Sep 8, 2007
    Orlando, FL
    Yep, that's pretty-much the correct procedure. If you're paranoid about jumping the 5th wheel, wait till you dump your first trailer !!! Just hope the thing isn't loaded. Checking the pin to be sure it's closed or even a tug test, doesn't always mean a trailer is locked onto you king-pin. Always do each test no matter what you hear or see ...
  7. teflondave
    teflondave Light Load Member
    172
    196
    May 22, 2012
    harwood, md
    we all have done it at one time or another so don't worry...after the first couple of times it happened to me I got myself into the habit of raising the landing gear of the trailer a little to make sure that doesn't happen...also when I drop I would usually leave about a two inch space between the ground and the landing gear, dump the bags and ease out from under the trailer...who wants to waste excess energy when you don't have to you know...also find a crowbar or a cheater bar or both...anyhow have a good rest of the day driver I'm out........
    snowblind Thanks this.
  8. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    The only time I ever did that was when I dropped my trailer so the yard dog driver could back it into the tight door inside building. When I went to hook up, I went under the fifth wheel. My airbags deflated and took several minutes to reinflate. I knew something wasn't right when I was backing up :biggrin_25510:
    I took a a piece of wood to pick up the rear of the fifth wheel plate and pulled forward. No biggie.
  9. koncrete cowboy
    koncrete cowboy Medium Load Member
    638
    331
    Jun 11, 2013
    Pennsylvania
    You said your gear wouldnt go up.put blocks under the pads and crank it downlifting the trailer up.tires turned all the wat to the right or left and then let er loose!!! Lol or if its a place witth lift trucks get someone to pick it up...
  10. tinytim
    tinytim Road Train Member
    5,145
    19,277
    Oct 29, 2007
    Northern Ontario
    No reason to be paranoid. It's not like the trailer jumped up in the air while you were backing under it. Just check next time.
  11. koncrete cowboy
    638
    331
    Jun 11, 2013
    Pennsylvania
    Blind drivers solution was prolly easier tho....
