Just another day with this ISX
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by HoneyBadger67, Oct 17, 2020.
  1. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    08 T660 ISX CM871
    Visor lights went out and I found a frayed wire. Took out the stuff iver the dash to feed more wire through visor hole and patched up wiring. Lights still didn't work, so I went through the box checking fuses. Got lights working again but now when I turn the key on my digital display goes to all dashes. Tried kicking the throttle 3X to see if there was a code but got nothing. As far as I know, I didn't step on any wires under the hood, just the valve cover. The lift pump doesnt work either...that's the first thing I checked when engine cranked but wouldn't start. Here's a picture of my display 16029807921278999808134375903375.jpg
  3. AModelCat
    165,225
    I'd recheck the wiring in the area you were working in. Looks to me like maybe the ECM isn't powering up.
    Goodysnap and HoneyBadger67 Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,782
    9,223
    Jul 12, 2017
    I agree with above. Knocked off a main power cable somewhere that was weak? Give a good look over wherever you went.
    HoneyBadger67 Thanks this.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Is there an ECM fuse?
    I found a 50A and a 60A on the firewall but those seem to big for that application
  6. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Checked all the connectors, they seem to be plugged in properly. It has "road relay 4" on it and all those connections seem okay, too.
  7. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
    check the ecm fuses in the battery box
  8. Claytonbigsby
    Claytonbigsby Bobtail Member
    46
    112
    Mar 31, 2019
    The blank dashes are a common glitch with both Peterbilt and KW many models, doesn’t matter what engine, there was an update to fix them years ago but it never really fixed them.
    Sometimes if you turn off the key for a few minutes until everything is asleep then open your door and they will work properly again. Rarely will they stay blank for more than a day
    D.Tibbitt and HoneyBadger67 Thank this.
  9. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Having the door open, numbers show. With the key on, though, all I get is dashes
    D.Tibbitt Thanks this.
  10. D.Tibbitt
    157,602
    That happened with my pete couple months ago. 15 mins and disconnect the batteries the reconnect fixed the problem
  11. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Will try that next
