Just bought 2 k40 6000 Watts!
Discussion in 'CB Radio Forum' started by TruckerPete1990, Oct 24, 2012.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    i just bought 2 k40 6000 Watts! i have a Cobra 29Ltd chrome. I put the k40 6000 on Now my ANT light is Red... before it wasnt. What can i do to get this fixed? Hopefully not to much money.
  3. MsJamie
    MsJamie Road Train Member
    How are they hooked up?
  4. jimvrg
    jimvrg Medium Load Member
    301
    83
    Jan 11, 2012
    yellville arkansas
  5. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    running normal wires thats with the truck mounted on mirrors like my old ones. i was using 2 6 1/2 foot fiber ones before didnt have that problem
  6. MsJamie
    Are you using the original cabling and mounts?
  7. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Yes the Mounts are along side of mirror and the metal clears the top of truck. Cabling is the Original.
  8. MsJamie
    And it still works if you put the original antennas back on?
    The only thing I can think of is that the K40s aren't tuned properly. Many CB antennas can cover the 10m ham band, and if they're set for the high end of 10, they will give a very high SWR on CB.
    There should be instructions on how to set up the antennas for CB. You may wish to seek out some local help on tuning.
    TruckerPete1990 Thanks this.
  9. Trashtrucker1265
    Trashtrucker1265 Road Train Member
    1,310
    944
    Dec 14, 2009
    Inverness, Fl
    Put the fiberglass antennas back on, or just try running one of the K40's. Why do you need antennas capable of 6000 watts when your radio is pushing 4, not 4000, just 4?
  10. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Mine tuned to 15 going to start gettin radio tuned up. Gonna stop in Dallas to get this fixed...
  11. Danger07
    Danger07 Light Load Member
    60
    5
    Sep 1, 2012
    The antenna ligts turn on for many diferent reasons especially when dealing with power. I cannot remember the screw name in the radio (but try to google it) that'll make the light go away. Dont get me writes ng it could be that there is a problem but try everything people tell you to do on here first but if nothing works andit bugs ya that the light is on there is a screw to turn to get it not to light up all the time. I suggest id you do this do it trial and error. Do 1/8th of a turn then key up and whistle into the mic, repete until the light goes away. That way if the problem is just the power as it could be, then the antenna light wll light up if there is an actual antenna problem.. but like i said so that as a last resort. If i find out what the screw name is called again ill let you know
