just got 2 citations
Discussion in 'Questions From New Drivers' started by Grind-o-holic, Sep 20, 2013.
  1. Grind-o-holic
    Grind-o-holic Bobtail Member
    8
    7
    Sep 17, 2013
    "not following electronic signal" and "impeding traffic"
    I missed the sign, that was no where even close to the exit, and couldn't have cleared the turn anyways. Waited for turn signal through 3 cycles, and traffic was too heavy.
    Any advise? Thanks.
    mje Thanks this.
  3. Grind-o-holic
    8
    7
    Sep 17, 2013
    sign was a no left turn sign
    mje Thanks this.
  4. kidsdad
    kidsdad Medium Load Member
    327
    298
    Nov 11, 2010
    central illinois
    All I can say is with more time you will learn not to miss anything, your brain is the most important tool you have. Train yourself to see every sign of all types all the time, not to mention it's part of your job. Use this as a learning experience, than move on. good luck
    b
    Grind-o-holic Thanks this.
  5. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    Fight every ticket you get
    Grind-o-holic and 123456 Thank this.
  6. Mrh2008
    Mrh2008 Road Train Member
    1,288
    310
    May 25, 2012
    Mesa, AZ
    Throw money at the problem. It'll go away.
  7. CobraDane
    CobraDane Light Load Member
    113
    60
    Jun 28, 2012
    Weatherford, TX
    If I were you, I would get on the phone to a lawyer that deals with CDL tickets. Even if he can't get the tickets dismissed, he can get them reduced to non-moving violations so it won't hurt your driving record. I have done that with a couple of speeding tickets.
    Thanks
    Paul
    Grind-o-holic and DrBigRig Thank this.
  8. DrBigRig
    DrBigRig Light Load Member
    70
    57
    Aug 31, 2013
    Speak to a professional ticket fighter. Learn something from the experience. You are a better driver for learning something here.
  9. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    Throwing money at the problem will not make it go away. Learn from your mistakes but if u care about your license look into hiring an attorney and fighting it.
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Many traffic tickets you can fight and get reduced to protect your driving record. Something like this I doubt there is no reducing or getting out of. You could hire a lawyer and a common tactic is keep putting the court date off and hope the officer doesn't show up is the only hope.
    Truck drivers see anything and everything. You have to improve your scanning abilities. You are new and you will get better at it. Sign, sign everywhere sign and you should know what everyone says or like this one you'll find yourself in a pickle.
    I take it you took a highway exit and at top of the ramp was no left turn? That case you make your right turn and find you a parking lot to get turned around in. That or go straight across and get back on the highway and get turned around at the next exit. Then you will be set up for a right turn on the other side. You don't ignore the signs to fix problems.
    Remember after conviction or admission of guilt by paying the fine you are required by law to report the event to your home DMV.
    123456 and Grind-o-holic Thank this.
  11. FSU
    FSU Light Load Member
    104
    58
    Sep 17, 2013
    Tallahassee, FL
    Yeah, fight everything. Even if the officer shows up, more times than not, the judge will reduce the find, withhold adjudication and assess no points. As long as it was a no harm no foul situation.
