K100G ABS Module - Bosch 0 265 151 202
Discussion in 'Kenworth Forum' started by Tim_Rob, Jul 31, 2024.
  1. Tim_Rob
    Tim_Rob Bobtail Member
    Hey all,
    Have a 1995 K100G with a N14 Cummins. Been a process going through the truck and fixing all the little issues.
    Latest one is the ABS system, changed the dash ABS bulb and its shining bright with a fault.
    Tried to google the Bosch ABS part number to determine how to diagnose it, but no luck what so ever.
    Anyone worked with the Bosch ABS ECU before? any idea how to get a fault code out so i can start to repair it all.
    Any information greatly appreciated!
  3. kemosabi49
    11,011
    48,102
    Jan 13, 2013
    SW Arkansas
    I didn't think ABS was required on a 1995 truck.
    Big Road Skateboard Thanks this.
  4. Big Road Skateboard
    7,265
    41,381
    May 2, 2021
    I think WABCO is the same as Bosch. Is there a switch to flash ABS faults? IIRC, a constant light means no power to the ECU. Check for a fuse
  5. Tim_Rob
    Just has three bulbs in a row, "Truck fault", "trailer fault" and "non abs trailer"
    I found the ABS unit mounted between the chassis rails, replaced all the fuses and confirmed I have battery voltage and ignition switch voltage (when turned on)
    May be I'll flip the lid open on the ECU itself and see if there is a fuse internally.
    I thought no light at all indicated no power to ABS?
  6. Tim_Rob
    Good news! Under the lid of the abs unit it has a test/diagnose button! Hoorahh. spits out some flashing codes so now I'm of and running to fault find the system and get it all working.
    So far discovered front left wheel sensor is out, s
