Keeping placards in place
Discussion in 'Questions From New Drivers' started by prosidius, May 7, 2017.
  1. prosidius
    prosidius Light Load Member
    252
    239
    Jul 15, 2016
    Wisconsin
    OK this is getting on my nerves. Placard on my passenger side keeping getting out of the holder and flying away on the freeway. Already used the 3 replacements the shipper gave me and 2 of the ones I bought at a truck stop. The holder has a clip that is supposed to keep it in place but it's not working.
    How can I keep the buggers in place so I don't risk a ticket?
  3. mitrucker
    mitrucker Road Train Member
    5,480
    10,286
    Dec 15, 2010
    Lapeer, MI
    Duct tape along the open edge of the holder is a common practice.
    ExOTR, Lepton1, Diesel Dave and 2 others Thank this.
  4. 48Packard
    48Packard Ol' Two-stop Shag!
    8,437
    10,224
    Apr 19, 2009
    Could be anywhere
    Clear tape. I'm never without it. In the absence of tape, you can try using some small pebbles or rubber pieces underneath the placard holder to help keep the placards in place.
    ncmickey, Longarm, G13Tomcat and 2 others Thank this.
  5. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    they sell sturdy clear plastic inserts made just for this, We get them from work, But the little rock trick will also work, But the DOT looks down on this
    G13Tomcat and 48Packard Thank this.
  6. Bob Dobalina
    Bob Dobalina Road Train Member
    2,578
    4,456
    Sep 20, 2015
    The "Buckeye"
    The sticker ones suck in holders. If you can't get the heavy paper kind, do a strip of tape over the open edge so it's on both the placard and the holder, or stick it onto cardboard you cut to the right size. Those are hard to get in and out, though. Tape is best.
  7. scythe08
    scythe08 Road Train Member
    2,897
    3,805
    Mar 19, 2007
    Portland, Or
    I use clear tape on all 4 sides. If it's winter or if there's a chance of rain, I'll wrap them in serranwrap then tape them.
    ncmickey Thanks this.
  8. Dave_in_AZ
    424,260
    Clear tape or sticky back placards. If your in an area that is prone to rain, I definitely recommend the sticky back ones, cause they are sticky as can be. You may spend 10 or 15 minutes ( each ) peeling them off, some come off in little pieces, but you won't get the citation of improper placard either.
    At least that's how I used to do it.
  9. MACK E-6
    50,023
    238,231
    I made the mistake of putting one of those in a holder once. It didn't stay. The ones designed to stick on never do.
    Bob Dobalina Thanks this.
  10. homeskillet
    homeskillet Road Train Member
    6,317
    48,882
    Jun 1, 2013
    Dayton, OH
    I almost got a ticket in Tennessee at the coop for having some fragments of an old red stick-on placard, so if ya put on a sticky make sure you get all of it off.
    tinytim Thanks this.
  11. tinytim
    tinytim Road Train Member
    5,145
    19,216
    Oct 29, 2007
    Northern Ontario
    A little heat from your blow torch and the plastic sticky ones peel right off in one piece.
    fargonaz and homeskillet Thank this.
