KeepTrukin ELD causes ABS and other lights on
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by NewRoute, Dec 12, 2017.
  1. NewRoute
    NewRoute Bobtail Member
    19
    11
    Jun 28, 2014
    Has anyone faced such issue with ELD? Freightliner Cascadia 2017 ABS, traction control and wheel spin lights are on while connected.
    Tech support keeps saying that they are working on it but the time is running out.
  3. Brandt
    Brandt Road Train Member
    4,642
    6,395
    Sep 17, 2012
    Sure you got the correct ELD. I hear on satellite radio some guy called in say same thing. The ELD maker said something about taking the information from the truck computers too fast was the problem. He was not a Keep truckin ELD just some could be sampling the buss information to fast and it could be messing up the truck computers a little.
    Seems like to me they would all be universal but he claimed some ELD were reading the information to fast. Something about it could be the wrong ELD or it needs an update in software.
    NewRoute Thanks this.
  4. NewRoute
    19
    11
    Jun 28, 2014
    Went to Freightliner dealer and installed all available updates. Lights are still on. KeepTruckin support doesn't pick up the phone. Horrible service.
  5. Port Man
    Port Man Bobtail Member
    23
    28
    Jul 29, 2017
    That's funny. I was wondering why my ABS light came on the first time I initiated my Roadlog Solo in my 2012 Cascadia. Fortunately Roadlog answers the phone and responds to emails. I'll ask them
  6. Tromano13146
    Tromano13146 Bobtail Member
    What was the outcome ...its happening to my 19 peterbilt 567
  7. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    My 2002 Century still does that once or twice a year.
    Don't know why, I just cut the truck off for a few minutes and start it back up, dash lights go off and it works again.
    A few times, last year, I had to disconnect the ELD, wait a few minutes, hook back up, get green light and it would work again.
    When my dash lights came on, the smart shift wouldn't up shift passed 3th gear. Crazy and very frustrating then.
    I haven't had any problems with it this year, so far.
  8. jlafume
    jlafume Light Load Member
    241
    324
    Jan 6, 2011
    Victorville,Ca
    I have the same problem with a 2010 prostar if I unplug it goes away. At least I dont have to drive in the dark
  9. NCTru919
    NCTru919 Bobtail Member
    49
    18
    Apr 23, 2021
    I had my Stop engine light and fuel in water light come on and truck died first time using the ELD not five minutes into drive. I pulled over and unplugged the Keep Truckin ELD and it’s worked fine ever since. I’m still intrastate hauling logs so I don’t need it at the moment but I was wondering the same question. If the ELD was causing fault codes. I have a 2014 Freightliner Cascadia 125
  10. 25(2)+2
    18,762
    46,074
    Sep 18, 2006
    the road less travelled
    Never had it in the 2013, I had heard of computer glitches with different ELDs and different engines. No problems with KeepTrucking in the 2018 I'm driving that I can blame on the unit.
    NCTru919 Thanks this.
  11. NCTru919
    49
    18
    Apr 23, 2021
    I ended up getting the fault lights again while not using the ELD a couple days ago. I swapped out the fuel filters and fuel water separator filter. Keep my fingers crossed There was quite a bit of particulate build up in the fuel water separator that actually caused some pitting in the metal, so I cleaned it real good and popped the new filter in. Let’s hope this does the trick.
    25(2)+2 Thanks this.
