Kenworth auto transmission problem
Discussion in 'Kenworth Forum' started by KY15, Jan 28, 2020.
  1. KY15
    KY15 Bobtail Member
    Jan 28, 2020
    I have kw t680 2015 paccar auto transmission. Sometimes when I change my shift from N to D , it doesn’t go nowhere. There is a light call ‘service’ beside the shift , puff up. And odometer (dash) where show shift number, say F. Then I turns of engine wait for 5 minutes, and it get back normal. Anyone can tell what’s wrong?
    johan52085 Thanks this.
  3. flood
    flood Road Train Member
    4,167
    4,045
    Dec 25, 2010
    Clutch...
    KY15 Thanks this.
  4. alo4646
    alo4646 Bobtail Member
    9
    10
    Jan 28, 2020
    check the clutch
    Vampire and KY15 Thank this.
  5. Ironmyke
    Ironmyke Light Load Member
    61
    57
    Jun 18, 2017
    Kansas
    Vampire Thanks this.
  6. Trucker t680
    Trucker t680 Guest
    Im getting same problem,, did u work anything out yet, wts going on with it??
  7. johan52085
    johan52085 Bobtail Member
    4
    I have the same problem with my 2017 kenworth T680 cummins ISX15 with Eaton Fuller transmission this is driving me insane someone please help me with these. My dashboard says transmission fault code and the service light next to the shifter flashes and then it does not let me shift into gear I turn it off leave it off for 2 to 3 minutes and then when I turn it on not only does it shift without a problem like nothing happen but the fault code is gone from the dashboard what is going on here.
  8. johan52085
    4
    Anyone that resolved this issue please share some knowledge with me.
  9. flood
    4,167
    4,045
    Dec 25, 2010
    what code is it showing....
  10. johan52085
    4
    I was not able to pull out the code I did the whole process it said online and it did not work I turned the key to the on position press and release accelerator pedal 3 times and instead of flashing the red light so I could count and get the code it did not worked the dash reads stop engine immediately at this moment so I turned it off gave it 3 minutes and when I turned it on everything was gone and working fine I dont have the fault code in dash board anymore because it goes away on its own I dont know if I can still retrive it.
  11. flood
    4,167
    4,045
    Dec 25, 2010
    Ta/petro can plug in (fee) and pull all active and inactive codes
