Kenworth auto transmission problem
Discussion in 'Kenworth Forum' started by KY15, Jan 28, 2020.
  1. johan52085
    johan52085 Bobtail Member
    4
    Good deal ill let you know as soon as I have it thank you very much for your help.
  3. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    dealers will do it also same free others charge. Either way they will tell you the code and what it's for. Clutch, cluch actuator, x y shifter, glitches in wiring....
    johan52085 Thanks this.
  4. Jatt07
    Jatt07 Bobtail Member
    Dod u figured out wt was the problem, im having same issue??
  5. Relentless2020
    Relentless2020 Bobtail Member
    Did anyone figure out the problem have same issue on my 2016 kenworth t680...I am also getting the (**) and won't let me go past 1400rpm. Replace TCM, x y shifter, transmission harness and speed sensor.
  6. Marcustbunch
    Marcustbunch Bobtail Member
    4
  7. Marcustbunch
    4
    Did you figure out what was going on to fix your issue? I'm have the same problem
  8. Marcustbunch
    4
  9. Marcustbunch
    4
  10. Fittrucker5
    Fittrucker5 Bobtail Member
    7
    Oct 14, 2021
    QUALITYTRUCK Thanks this.
