Kenworth auto transmission problem
Discussion in 'Kenworth Forum' started by KY15, Jan 28, 2020.
  1. Fittrucker5
    Fittrucker5 Bobtail Member
    7
    Oct 14, 2021
    QUALITYTRUCK Thanks this.
  3. Knightmc
    Knightmc Bobtail Member
  4. drewfarmsllc
    drewfarmsllc Light Load Member
    84
    32
    Oct 18, 2008
    South Carolina
    My 2020 t680 with auto is showing this fault. Has anyone figured out what this is?
    I can't seem to run it down. It's doing what alot of you are saying. Gives this fault then when it goes into n it won't go into d or r until I switch it of and restart
  5. Mhfierro
    Mhfierro Bobtail Member
  6. Mhfierro
    I have the same problem on a 2020 t680
  7. Lorena
    Lorena Bobtail Member
    @Mhfierro Did you ever find out what it was?
    I have same truck 2020 T680 and it’s doing same thing
  8. drewfarmsllc
    84
    32
    Oct 18, 2008
    South Carolina
    Fixed my 2020 by putting a new right hand shifter on. Very easy to do. Bad thing is it runs about a grand.
  9. AModelCat
    165,310
    That's nuts. Any fuel savings you might see between the auto and manual are wiped out with a single repair.
  10. MaximusRussian
    MaximusRussian Bobtail Member
    Oct 14, 2024
    I have 2020 t680 with 533K miles. It started today by not going into a gear, having hard time switching to gear 9 and up, not getting out of N, flashing gears 8,9,10. Then message in yellow to stop for service or whatever I can’t remember precisely what it says, then red message to stop completely to prevent any damage. What kind of crap those transmissions are ? Mine is Fuller 12 speed.
  11. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    X-Y shifter.. known to start having problems after 550k. Clutch actuator/clutch.
