Hey guys, I'm having my W900 moved piggyback style and wanted to know if the 2" reciever mounts will fit an ordinary hitch ball mount.
Just need to know how far the pins are inset from the front.
I need to be able to lift the truck off of the towing unit. (Have access to a wheel loader.)
Thanks.
Kenworth bumper reciever mounts
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pcfreak, Dec 23, 2008.
A 2" receiver won't work without modifying them. The end that goes in, needs to be cut down with a torch and ground to go in far enough to be pinned. The 2" part is only ~2" deep. The holes are another 1" or 2 back in farther. Take a closer look, and you'll see what I mean. If you know someone that has OEM tow pins, look at them as well.
pcfreak Thanks this. -
Thanks. Do you think they'd be strong enough to lift the truck from the front?
If you are careful, and use 2 tow pins, you should be fine. Just take it easy.
You can get the tow pins on Ebay pretty cheap.. They're strong enough to pull my fully loaded water truck out of the mud (47,000lbs)
I've seen the OEM pins, and was NOT impressed. The rear pin hole on them is so big, there isn't much material left. They should've left the pin holes as 2" or so all of the way back. Unless, they were thinking to use them as the weak link so you wouldn't rip the truck apart.
We've made our own, and use just a 5/8" hitch pin. Haven't even bent one pin with a fully loaded 18.pcfreak Thanks this. -
I just had a thought. 5/8" chain should fit inside the hole right?
Just put the pin in the first link and some 2" box near the edge to keep from ripping anything apart.
Looking at grade 70 chain 15800lbs working load.
I'm not setting myself up for trouble am I? -
it want take much to lift it off you just don't want to get in the grillpcfreak Thanks this.
Just last saturday, a loaded end dump got stuck in a dirt/mud lot in our little town. A loaded bobtail water truck went to his aid, using a 3/8" chain. He could not be pulled forward because of placement, and obstructions. The water truck actually had to skid the tractor around in order to pull the rig onto the highway. I happened to be passing by, and the first one they stopped when the water truck backed partially off the highway to hook-up. The amount of stress put on the chain caused me to duck down in my p/u, expecting a broken link to go flying into my windshield. Hard to believe how much that torture that chain took.
Definately. Just need some square tubing for the chain to go through to move it out from the truck a few inches.
