I have just replaced my heater control valve in the bunk of my KW. If anyone has done this they will find out that the new style of valve just has a big o-ring that you put on the heater core line that hooks to the valve and you slide a c- clip in to hold it in place. The old one has the same type of set up but it is secured with four little screws on a flange that holds it together. I have put the new valve in and installed as it says in the directions and it leaks. Just would like to know what or if anything I did wrong.
Kenworth bunk heater control valve replacement
Discussion in 'Kenworth Forum' started by Fishell Trucking, Sep 10, 2016.
