Kenworth T600 a/c issue
Discussion in 'Kenworth Forum' started by Junior2404, May 5, 2021.
  1. Junior2404
    Junior2404 Bobtail Member
    Hello I have a 2006 kenworth t600 and it keeps busting the hose that go from the a/c compressor to the condesener any suggestions on what can probably be the cause?
  3. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    As in blowing the line apart?
    In order
    A. Make sure the hose isnt rubbing something weakenimg it
    B. Check your high pressure switch cutoff if its there/fan cut-in
    C. See if compressor has an internal pressure bypass if it does and its clogged, that can do it
    D. Freeze switch working?
