Kenworth T700 antenna
Discussion in 'CB Radio Forum' started by joseph1135, May 7, 2012.
  1. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,301
    Nov 8, 2009
    The Highway To Hell.
    Ive got a 2012 KW T700. I'm running a Connex 3400 HP. I can talk as far as I want, I can't receive worth a crap. So, I know it's an issue with the antennas. Problem is they are mounted on the side of the cab. Without having to go to a cb shop and hear the guy ramble on about nothing, whats the best antenna I can pick up for this truck without having to mount another one on the back of the cab? I also have a Galaxy 44 I'm thinking about running again, putting the Connex in the back for a while.
  3. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    What are you running right now ?
  4. joseph1135
    11,340
    27,301
    Nov 8, 2009
    Right now I'm running the Connex with the stock antennas (I know, I know lol).
  5. cuzzin it
    cuzzin it Road Train Member
    3,647
    12,802
    Jan 19, 2008
    Berea, KY
    Without wanting to change out the cable, i'd look for different antennas, is Taller feasible ?
  6. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    for better service put 1 out back like on a pb 387/kw t2000 style mount with separate coax. That is going to be your only option with that fiberglass truck.
  7. joseph1135
    11,340
    27,301
    Nov 8, 2009
    If you do close up of the my sig pic, that's my truck, so, lol, no, taller can't work. I'm thinking of buying some Wilson fiberglass antennas. I don't want to drill or run coaxial cable outside, I just wanted a better alternative. Thank you to everyone for your input!
  8. Jeremyc
    Jeremyc Light Load Member
    266
    90
    Feb 29, 2012
    The Great Lakes
    I think you may be stuck if that's the case.
    For what its worth, I have seen a perch type mount for either the T700 or the Cascadia (or both) that mounts where the single mirror mount connects to the door. Maybe that allows you to run the coax through an existing hole in the door?? That would eliminate one of the things you don't want to do. That should allow you to run virtually any antenna you want, probably up to 7'.
    I think I'm going to be getting a truck real soon that has this same set up, so if anyone knows where to find this type of mount, please share.
  9. Jeremyc
    266
    90
    Feb 29, 2012
    The Great Lakes
  10. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Actually that is not his only option. I drove a 387 Pete with stacked dipoles mounted to the outside of each fairing, and had a 40 mile range. If I did it again, I am sure my range would be greater now, because since then I have found a much better radio technician. It requires minimal fabricating and is totally doable.
  11. mike5511
    mike5511 Road Train Member
    3,157
    1,547
    May 15, 2011
    NW Arkansas
    Got any pictures of this set up????
