Kenworth t800 no dash lights
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fritzybabe, Apr 1, 2024.
  1. Fritzybabe
    Fritzybabe Bobtail Member
    10
    Dec 6, 2023
    Had several lighting problems I posted about earlier, fixed most of those but still have no dash lights. Lights come on when you turn the key on, gauges all work, checked fuses, relays, everything good, don't know what to check next.
  3. Lazer
    Lazer Road Train Member
    1,852
    2,988
    Jan 22, 2017
    Dash light dimmer switch gone bad?
    Fritzybabe Thanks this.
  4. Fritzybabe
    10
    Dec 6, 2023
    I was wondering about that, but for 130 dollars I wanted to check every thing else first. Is there a way to test that? Like maybe jump the plug to see if they come on?
  5. BigManTN92
    BigManTN92 Bobtail Member
    4
    Apr 23, 2024
    Nashville, TN
    That’s what happened with my truck and it was intermittent until finally just went.
  6. Fritzybabe
    10
    Dec 6, 2023
    That's what it ended up being, the dash dimmer switch. That's one headache gone, now I have an air tank leaking and it's actually a pair of tanks together mounted under the battery box, there are none to be found so apparentley they have to make them, 2000 bucks and 2 weeks.
  7. BigManTN92
    4
    Apr 23, 2024
    Nashville, TN
    Always something, smh. Hopefully the tires stay rolling for a long while afterwards. I just joined here to figure out something with my a/c. It doesn’t blow as hard or as cold at an idle and I can’t find anywhere if I have a recirculating filter or not. Hoping I can find an answer here, but they won’t let me start a conversation until I did seven comments unfortunately.
  8. Lazer
    1,852
    2,988
    Jan 22, 2017
    If the ac blower motor noticeably slows down when engine is idling, check the alternator for proper voltage output.
    BigManTN92 Thanks this.
  9. Fritzybabe
    10
    Dec 6, 2023
    If you got a t800 2007 or so , the filter is on the outside under the hood on the passenger side, witch I thought wasn't a very good place for it When we got the truck it didn't even have a filter, so the a/c condenser and heater core were plugged. Had them cleaned and it works much better, you might check that out.
  10. skallagrime
    skallagrime Road Train Member
    3,855
    9,929
    Apr 10, 2012
    Indiana
    Part of the issue on the old kws, that filter IF it has it, does nothing for recirculation, also the ac box is powder coated steel and rots out
  11. BigManTN92
    4
    Apr 23, 2024
    Nashville, TN
    Appreciate guys, thank you!
