keywords that 2013 keeps shutting off...
Discussion in 'Kenworth Forum' started by greenfirelady, Oct 22, 2013.
  1. greenfirelady
    greenfirelady Light Load Member
    64
    12
    Jul 15, 2013
    How doi idle this silly thing?? I REALLY don't want to bake to death in the AZ heat. ..A little help please? And I don't have an apu on the truck. ...thanks!!
  3. Chinatown
    Chinatown Road Train Member
    77,751
    184,490
    Aug 28, 2011
    Henderson, NV & Orient
    A few trucks will continue to idle if you bump the cruise control button. Some companies are wise to this and made it so this doesn't work.
  4. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    This used to work, release tractor brakes and use trailer to park...bump cruise......
    No? Get stick for throttle.....
    No? Yell on radio for ECM guy to plug in and turn off shut down....remember tho, carrier watching mpg's. Throw a little cash in tank to balance mpg and keep carrier off balance. Also works to get fuel bonus....and tax deductible!!
    Good luck...
  5. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Chock the wheels real good as in #### near park on top of them and then release the brakes . Or as stated above apply trailer release tractor it actually should work cuz if it didn't you would be shutting down in rush hour lol
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    yep, use trailer brake ONLY.
    however, there may be a possibility where truck may still shut down. if it senses no movement after a period of time. if it's possible for ecm to have such parameters.
  7. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    The weather in Az. isn't all that bad, just do the window and flaps thingy and hang in there!
  8. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    The parking brake trick rarely works anymore, especially on newer trucks. The last 4 trucks I have had (2) 2012's, (2) 2013's and it didn't work on any of them. They will still shut off after 15 mins of non movement with the parking brake released
  9. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    many new truck wont idle over 5 min unless its over like 80 degrees. (company can set the temp) I knew a guy who plugged a hair dryer into his inverter and left it bowing on the temp sensor so he could idle his truck lol.
    Blu_Ogre Thanks this.
  10. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    911
    Mar 16, 2013
    Get your favorite shade tree mechanic to do some "maitnence" on it.
  11. Jorihe84
    2,763
    1,333
    Sep 1, 2010
    North Florida
    And get fired when the company finds out
