Kingpin depth
Discussion in 'Flatbed Trucking Forum' started by MicksRule, Jul 20, 2020.
  1. MicksRule
    MicksRule Medium Load Member
    412
    354
    Dec 20, 2009
    Apple Valley, CA
    Kind of in the market for a new flatbed. I'm used to pulling a 48 step with a 13" kingpin set way behind center of axles due to an 8' upper deck.
    What are the pros and cons of the various kingpin depths on a flat? I'm seeing 12,18, 24, 30 and 36" settings with 24 and 30 being the most common.
  3. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,798
    Aug 12, 2007
    Kansas city,Mo
    The more shallow the king pin the more you can hang off the front.
    The only reason I see for a deeper kingpin to the meet the KPRA laws in certain states.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    Well, there is the weight issue too. With a regular depth, I get a little weight on the steer, drives, and try to keep the spread under 36,000. I don't know how much a 13" would be.
  5. kylefitzy
    4,752
    19,798
    Aug 12, 2007
    Kansas city,Mo
    You would load a 18” kingpin trailer 1’ farther forward then a 42” kingpin trailer and end up with the exact same weights.
    Bean Jr. Thanks this.
  6. Cat sdp
    Cat sdp . .
    21,280
    76,011
    Apr 8, 2012
    Orion's Belt
    18”..... is all I know
  7. Bean Jr.
    5,573
    9,929
    Mar 30, 2014
    Mine has a bulkhead, so i didn't really think of that.
  8. Tug Toy
    Tug Toy Road Train Member
    7,054
    73,843
    Jul 4, 2015
    Corn field
    I had the king pin and plate replaced on my high boy flat (rusted out) Was 24” and I had them replace it to 12”. Love it. It gives a foot more front overhang and didn’t really change the center as far as I can tell. 5th wheel is right at the front of the plate now.
  9. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Bear in mind the deeper the pin setting, the closer the landing gear will be to your mudflaps. Also the further it will stretch your air lines (sometimes too far) in sharp and over 90 degree positions
    Con of a really short king setting is that you can occasionally drag the air lines on the 5th wheel plate in sharp turns resulting in a mess of grease all over them
    Both airline scenarios assume a somewhat typical airline off back of cab to front of trailer
    Only other thing I might consider is if you get on your step deck from your truck catwalk, the deeper pin settings are less likely to have you step in the 5th wheel grease that runs off the front edges of the fifth wheel, but a big gob of it might land on the catwalk far further forward than you're used to
  10. thejudges69
    thejudges69 Light Load Member
    246
    316
    Aug 22, 2015
    Shallower kingpin and a rear set wheel will be hard to load the steer axle. Flatbeds are typically 30-36" kingpin. I person run a 30" on my stepdeck, but I have 11' top deck.
    If I bought another flatbed it would have a 30-36" kingpin to get the weight on the drives and off the trailer. And I'd have the fifth wheel set at center of the axles on the drives. I'm surprised you can get any weight up front with that wheel so far back.
    Bean Jr. and nikmirbre Thank this.
  11. cke
    cke Road Train Member
    6,123
    75,421
    Aug 4, 2013
    Colfax Wi
    My pin setting now is 24 inch. Next trailer will probably be 20 inch pin setting
    IH Truck Guy, Tug Toy and nikmirbre Thank this.
