Kingpin K536M installation.
Discussion in 'Volvo Forum' started by Snailexpress, Jul 23, 2019.
  1. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Looking for help how to install them properly. Manual says final torque for the nut is 600 ft-pound. Didn't say anything about how to measure knuckle vertical play and install shims. If shim is too thick bearing will be locked. If shim is too thin knuckle will play.
    Thank you.
  3. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I never done this, i watched this video recently but not torque specifications, some tips for Meritor FastSet No-Ream King Pin Kit.
    Snailexpress Thanks this.
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Thank you. This is different style .
  5. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
  6. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    So this king from what i have done in the past and experience there is a way to just tight it up and not neccessarily replace it i've only had the need to replace once but usually i take it apart loosen clean it up and reassemble back tight it properly and never had a problem.
  7. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Do you remember nut socket size by the chance?
  8. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    I think it’s 2 5/8 but can not tell for sure will let u know tomorrow what I use.
