Kingpin location rearward from front of trailer?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Deezl Smoke, Mar 27, 2011.
  1. Deezl Smoke
    Deezl Smoke Medium Load Member
    572
    387
    Feb 12, 2011
    Hillsboro Oregon
    Hi all.
    In a non-commercial setting, landing gear not included, and using an empty trailer for example, what is the maximum distance rearward of the front of the trailer that a kingpin can be located? Legally or clearance wise? Cab clearance is not included as we'll use a 280" wb daycab for the example.
    I should also include that the trailer would be custom made and the fifth wheel plate would be minimum 6" higher off the top of the frame than standard commercial settings, so the chance of the front of the trailer contacting the tractor frame is quite low.
    Is there a legal formula that the law uses to determine this? Or is it even determined unless the trailer swings outside the arc of the front tires?
    Thanks.
  3. special-k
    special-k Road Train Member
    1,523
    3,259
    Dec 27, 2008
    Southern Ontario Canada
    There's no legal distance just whatever works for your application. 36" is a common # for vans. I would think having a lot more than that would make swing an issue with the front of the trailer. If your trailer is narrrow it wouldn't matter in any event.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    Do you build an RV Van. Here some peple use old refers
  5. 98989
    98989 Road Train Member
    5,991
    6,742
    Sep 14, 2008
    here in Europe we have 2040mm (6´ and 8 1/3" ) from king pin to front corner legal limit ( it is by ISO 1726) some other countries ( Scandinavian one ) they use other king pin location so their distance from king pin to corner on trailers are about 200mm more than ours
    some trailer have two king pin location
    anyway you by our law landing gear must be 2300mm from king pin (7.5´)
    also you need at least 7 degrees of "minimum angle of inclination" forward and 6 rear . for low coupling height 5th wheels you need 4 degrees forward and 2.5 on rear
    basicly thats it
  6. Deezl Smoke
    572
    387
    Feb 12, 2011
    Hillsboro Oregon
    Thanks for the replies.
    Pablo, yes, I am wanting to build an rv trailer. It is not a refer, but is an aluminum roofed, 12'6" high dry van.
    Thanks.
  7. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    additional thermal insolation will be requrired. We did it with old Lamberett refer, cut windows with nibbler, we purchased railvay car windows (there is a plant in our town) and doors. It is really warm inside, two Webasto Air Top 5000 heaters were more then enought. summer cooling was a prblem till we got APU.
  8. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,042
    Dec 17, 2008
    There is a company out west that uses a very long kingpin setting with 57' long trailers. I think the kingpin is 7' from the front to accommodate the kingpin to trailer axle length laws.
    As far as restrictions on this type of combination, I don't think there are any. You have to deal with the individual states the truck and trailer is going to travel in and the restrictions they will impose upon you.Which will be overall length, inner bridge, kingpin to centerline of rear axle or tandem. Also if the tractor and trailer combination is registered as a private coach, you maybe exempt from some or all of these restrictions
  9. Deezl Smoke
    572
    387
    Feb 12, 2011
    Hillsboro Oregon
    Thank you Mr. Haney.
    The RV is exempt from a lot of commercial abides, but it is limited in length to 45' solo and 65' combo at least here in Oregon.
    Thanks for your reply.
  10. Strider
    Strider The Info Monster
    137
    1,996
    Aug 30, 2010
    Kansas City
    I'm aware of just ONE state, Maine, who would possibly take issue with the kingpin far back on the trailer, although when I just now looked for it, it seems to apply only to trailers over 48". I believe I read elsewhere some time ago that it applied to any semi trailer... perhaps it has since been changed. It still leaves me shaking my head, asking, WHY?
    Title 29-A, sec. 2390, 1J, (2)
    "(2) The kingpin setback of the semitrailer, measured as the distance from the kingpin to the front of the semitrailer, may not exceed 3 1/2 feet in length"
  11. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    And up here the trailer or load cannot be more than 10 feet ahead of the fifth wheel pin.
