Kleenoil Filter For ISX Engine
Discussion in 'Peterbilt Forum' started by eng.moh.4u, Feb 4, 2023.
  1. eng.moh.4u
    eng.moh.4u Bobtail Member
    40
    4
    Jan 13, 2017
    Hi,
    I got a used Peterbilt truck and when check engine side I found a kleenoil filter installed to on the engine bay
    Any idea what this filter used for? And what will happened if removed from engine?
  3. eng.moh.4u
    40
    4
    Jan 13, 2017
    Please any info for this type of filter?
  4. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    QUALITYTRUCK Thanks this.
  5. JB7
    JB7 Road Train Member
    1,020
    1,808
    Dec 13, 2022
    Laurel, MD
    Why would you want to remove this bypass oil filter? Mann+Hummell makes a centrifuge bypass filter which is an option on the Paccar engines as part of what they call a module. Also make the Spinner II.
    The Kleenoil Bypass Filter System is a bypass oil filtration system that passes only a small portion of the total oil flow through a very dense filter cartridge at about 2 to 3 quarts per minute. At this speed, it is possible to remove particles down to 1 micron (3 absolute) and remove 99.95% of all water, greatly decreasing engine wear and prolonging oil life. Kleenoil can eliminate water and particle contamination, extend oil life up to 5 times and hydraulic oil up to 10 times, reduce engine wear and component wear, dramatically reduce downtime, remove particles down to 1 micron (3 absolute), and is applicable to engines as well as hydraulic systems.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I’ve had the Kleenoil bypass filter on three of my trucks. It’s the same idea as the Gulf Coast or the OPS.
    I think it’s a British manufacturer, they have a website and have distributors across North America.
    I usually bought a case of filters at a time.
