KW and Peterbuilt recall
Discussion in 'Trucks [ Eighteen Wheelers ]' started by quatto, Mar 6, 2017.
  1. quatto
    quatto Medium Load Member
    588
    980
    Mar 9, 2013
    The Bluest State
    http://www.landlinemag.com/BizBuzz.aspx#862
    Paccar is recalling more than 400 Kenworth and Peterbilt trucks, according to National Highway Traffic Safety Administration documents that cite an issue with the fuel system. According to NHTSA, the problem affects model years ranging from 2015 to 2018.
    More specifically, the plastic fuel tee fittings may leak fuel in the engine compartment. A potential fire can occur if this fuel leak reaches an ignition source.
    The following trucks are affected by the recall:
    • 2015-2018 Kenworth K370
    • 2015-2018 Kenworth T680
    • 2015-2018 Kenworth T880
    • 2017-2018 Peterbilt 567
    • 2017-2018 Peterbilt 579
    Owners will be notified and dealers will replace the fuel tees for free. A notification schedule has not been released. Questions can directed to Kenworth customer service at 425-828-5000 and Peterbilt customer service at 940-591-4000. Paccar's numbers for this recall are 17KWA and 217-A.
    rank and Oxbow Thank this.
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    And that folks is why you don't use plastic in a rolling oven disguised as a truck.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    There is a misconception that diesel is harder to set off than gasoline. It does have a higher flashpoint than gasoline, which is the temperature that it will ignite with a source of ignition. The autoignition point is lower than gasoline 410° vs 477°. Pretty easy with the heat of today's exhaust to set diesel off!
    quatto and Oxbow Thank this.
  5. Tall Mike
    Tall Mike Road Train Member
    7,689
    36,843
    Aug 20, 2014
    New York State
    I guess I'm safe for now those appear to be all aero trucks listed..
    aka mega fleet specials
    Bean Jr. and rank Thank this.
  6. AModelCat
    164,695
    All in the quest for lighter weights and lower cost to produce.
    Plastic has no place in trucks IMO. Tried and true steel, aluminum and brass. Heavier yes but at least the truck survives past the warranty period lol.
    Bean Jr., quatto, rank and 3 others Thank this.
  7. Oxbow
    Oxbow Road Train Member
    13,663
    141,656
    Nov 24, 2015
    I'm not sure they are really heavier.
    MJ1657, Bean Jr. and SAR Thank this.
  8. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    You're right they're lighter
    MJ1657, Bean Jr. and Oxbow Thank this.
  9. SnowMan24
    SnowMan24 Bobtail Member
    24
    129
    Apr 27, 2008
    Alexandria, Minnesota
    My gut is telling me that these are only for Paccar MX powered chassis, they use lots of plastic fuel connections. I tried looking up the recall and it's not even listed in our system yet, last one available is 16KWA for a headlight issue.
    (BTW: I am a Kenworth dealer mechanic)
    MJ1657, quatto, SAR and 2 others Thank this.
  10. Belials
    Belials Light Load Member
    232
    216
    Jun 10, 2014
    Paccar warranty manager here. No recall notices have been released as of yet. Haven't heard anything about it, either.
    Bean Jr., quatto, rank and 2 others Thank this.
  11. quatto
    588
    980
    Mar 9, 2013
    The Bluest State
    Are you saying the notice is false?
    MJ1657 Thanks this.
