KW Flashing Head Lights?
Discussion in 'Kenworth Forum' started by Svoray, Jun 17, 2011.
  1. Svoray
    Svoray Medium Load Member
    558
    194
    Feb 3, 2011
    Texas
    My usual truck ended up in the shop and had to take a 2000 KW bobtail (triple axle tanker) on a job yesterday. Well the job ended up running way behind which is typical. Anyhow, while I was looking around for the boss man to sigh off on my paper work, I noticed the head lights on my truck was flashing? This is a new one on me. I cut the lights off and on a couple times and that seemed to do the trick...so I thought. I got about 10-15miles down the road and the lights started flashing again! So I pulled over a fooled with the lights again until they stayed on. Once on, I started driving down the road and got another 10-15 miles when the head lights started flash again. It did this the entire way back to the yard!!
    Has anyone run across this before?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    maybe its one of those good buddy trucks i hear about. run away never look back!!
    aiwiron Thanks this.
  4. dieselpowerrules
    dieselpowerrules Light Load Member
    248
    37
    Feb 24, 2011
    Wisconsin
    There is a circuit breaker that keeps tripping, causing the flashing. You need to find the short or whatever is causing the breaker to trip, and it'll be fine.
  5. Sparkz
    Sparkz Light Load Member
    76
    16
    Jul 10, 2011
    New Zealand
    Yes, probably is circuit breaker tripping.
    May just be that breaker is old and tired.
    Has someone fitted high wattage light bulbs?
    Has someone fitted extra lights that also run through the breaker?
    You need to test the headlight current with an ammeter.
  6. ptours93
    ptours93 Bobtail Member
    37
    4
    Sep 12, 2011
    orland park il
    you should check the relay for hd/lite swap it out w/other one.that's prolly your problem.
  7. drwye
    drwye Bobtail Member
    7
    4
    Aug 27, 2011
    KingsvilleON
    Check the relay, most likely causing it. Like ptours93 swap it out for a less used relay like flood lights.
  8. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I have had corrosion on a fuse cause this before with my marker lights.
  9. oregon1001
    oregon1001 Bobtail Member
    7
    Oct 30, 2011
    Tangent,OR
    I had the plugin loose on the firewall, engine side. Pulled apart cleaned and fixed problem.
  10. ptours93
    37
    4
    Sep 12, 2011
    orland park il
    good info . to know
  11. kustom
    kustom Light Load Member
    59
    25
    Aug 11, 2010
    coos bay, oregon
    The most common overlooked problems are related to grounds. You didn't say which hood you have, but i would check your ground.
