L10 Cummins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BigRig1980, Apr 11, 2020.
  1. BigRig1980
    BigRig1980 Bobtail Member
    27
    10
    Feb 26, 2020
    Would installing a turbo off an n14 help or add any power or would I be wasting my time. Reason I'm asking is I have approximately 10 of these turbos brand new from Cummins and wouldn't mind getting some more power out of it without having to swap in a Detroit or 3406b cat engine.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,552
    6,642
    Aug 26, 2014
    There is no substitute for cubic inches. L10 is about 610 CID.
    If the turbo will even bolt up you need a balanced system. Fuel, air, exhaust. Just adding one of them sometimes makes things worse.
    Deere hunter and Bean Jr. Thank this.
  4. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    What's up with the turbos? Where are they ? And how much you want per a unit or for the whole lot?
    Brand new or rebuilds.
    Deere hunter Thanks this.
  5. BigRig1980
    27
    10
    Feb 26, 2020
    I get that part its sort of like the m11 lol. But what I'm curious about is if I installed an n14 turbo and tweaked the pump and ran a straight stack on it would it pick up any power/torque?
  6. BigRig1980
    27
    10
    Feb 26, 2020
    Here at my shop middle TN.
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    It may help at hi rpm but will have a case of turbo lag at low rpm like a much lower hp eng. at lower rpm?
    BoxCarKidd Thanks this.
  8. 201
    201 Road Train Member
    12,808
    26,367
    Apr 16, 2014
    high plains colorado
    Never cared for the L10. Back in the 80's, company I worked for got several new Louisville Ford tandems with L10 motors. Some slick salesperson saw them coming with lofty claims of 10 mpg. Yeah, on paper maybe, but grossing 80K, foot to the floor all day, didn't get any better mileage than a BC, and we burned them out in a year and a half.
    Deere hunter, AModelCat and BoxCarKidd Thank this.
  9. BigRig1980
    27
    10
    Feb 26, 2020
    I'm more wanting low end torque or mid range. I don't need a hotrod my w900 is that lol
  10. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    you better put a lot of fuel on that L10
  11. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    if You like major boost lag and no power coming out of the hole, then by all means do that swap
