Landing gear height?
Discussion in 'Questions From New Drivers' started by GILL, Mar 23, 2012.
  1. GILL
    GILL Bobtail Member
    9
    Fort Lauderdale
    Is it true that you only need to raise landing gear 4 inches off the ground?
  3. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    By regulation or common practice?
    I raise them almost all the way up. And I do drop and hooks all day.
    The extra cranks help burn calories! Which I sorely need.
    Mikeeee
  4. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Sure if you are only driving on level even ground. Wait till you go into some driveways or uneven terrain and see what happens if you leave your landing gear low.
    It's best to crank them all the way up to save some $$$$ and embarrassment
  5. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    Crank your landing gear all the way up. If you don't, sooner or later you will wish you had.
    otherhalftw, Sublime, NYROADIE and 3 others Thank this.
  6. marmonman
    marmonman Road Train Member
    1,417
    2,843
    Dec 14, 2009
    central illinois
    That is a good way to meet the driver of the freight train when you get hung up on a R/R crossing !!!!!!:biggrin_2555:
    123456 Thanks this.
  7. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    Who cares if its true, why would you even consider not raising it all the way. Straight up lazy.
  8. Pmracing
    6,354
    3,178
    Jan 28, 2011
    I know there is that notch in the fifth wheel post, but can slamming your landing gear on the ground going over a hump cause the trailer to unhook?
    Mikeeee
  9. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    It may not come unhooked I personally have never seen that, but it can cause you to loose the landing gear or your job! Just raise it up doesn't take that long and jobs are hard to find. not to mention if you meat that Train engineer it may be in Heaven as every trucker has done his time in Hell.
    Mommas_money_maker Thanks this.
  10. Allow Me.
    10,779
    12,630
    May 28, 2009
    Rancho Mirage, Ca.
  11. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Crank all the way up then back it down 1/4 turn....in case the grease or gear seize, you have two directions to move even if it is only an inch....better chance to break it loose!
